shifting problem
Old Aug 16, 2009 | 06:48 PM
dj-t's Avatar
Default shifting problem
I have a 96 prelude si automatic and the problem is that I cannot put it in park no more nor in drive. This happened after i swap the motor. Whenever I shift it it grinds, I have to turn off the car in order to put it in park. I thought it was the trans since when I put it in park I can still push the car as if it is in neutral so I went ahead and bought a used trans installed it and still the same thing. The only thing that I can think of now is that maybe the shifter cable or the shifter itself.
Has anyone experience this before or what could it be that is causing this?
Old Aug 16, 2009 | 07:16 PM
Kronn 98SH's Avatar
Default Re: shifting problem
Are you using a MT ECU?
Old Aug 16, 2009 | 08:04 PM
dj-t's Avatar
everything on this car is stock no modification done at all. it worked fine before I took the car through the car wash. at the end of the wash i put it in drive and it started grinding.
Old Aug 17, 2009 | 02:24 PM
Kronn 98SH's Avatar
WTF dude? In your original post, you clearly stated that you swapped the motor. Now, you're saying everything is stock. It can't be both.
Old Aug 18, 2009 | 01:45 PM
dj-t's Avatar
Sorry, I meant I swap the old h23 motor for a new rebuilt h23 motor but other than that everything else is still stock.
When I start the car when it is in park I can shift it out without grinding put when I put it back into park it grinds. It also grinds when I try to put it in drive but reverse does not grind or anything it just doesn't even work.
Old Aug 18, 2009 | 03:52 PM
street_ride14's Avatar
Either installation error or defective trans.
Old Aug 19, 2009 | 09:15 AM
dj-t's Avatar
Everything seems to be put back the same way as when I took it off. What about that lever that is in front of the trans which has a cable that attached to the throttle body. The cable on lever also has a adjustment just like the throttle cable for tension.
h23prelude94
Feb 5, 2009 05:39 AM
Andrew87
Aug 4, 2005 10:38 PM
Ls4thGen
Mar 7, 2005 12:25 AM
Nataku
Sep 1, 2004 12:42 PM
BoostFrenzy.com
Mar 14, 2004 09:42 AM
