Can't Find Timing Mark....
Old Jul 28, 2009 | 07:10 PM
black94lude's Avatar
Default Can't Find Timing Mark....
I just finished swapping in an H22A1 motor in my car but I used my old H23A1 crankshaft pully with the motor instead because the crankshaft pulley on the H22A1 motor has a huge crack on it. When I when to check my timing with the timing light, I wasn't able to find the timing mark on the H23A1 crankshaft pulley and the motor. So I was just wondering if anyone knows where the timing mark on the H22A1 is at? Or is that since Im using the H23A1 crankshaft pulley I wasn't able to see the timing mark. Any help would be very appreciate it....
Old Jul 28, 2009 | 07:52 PM
HdeucedeuceA's Avatar
Default Re: Can't Find Timing Mark....
The timing mark is on the flywheel. There's a little hole to the left of your exhaust manifold, on the tranny.
Old Jul 28, 2009 | 08:56 PM
oranginal's Avatar
where the tranny meets the block right above where the lettering h22a1/r is located you remove the rubber grommet and look for the white timing mark on the flywheel and align that while looking through the alignment marks on the right side.
however make sure you get the right mark at there is a 5* mark and then some red marks, then the right mark.
Old Jul 29, 2009 | 11:41 AM
So these alignment mark is that right side of the motor but does it locate on the plastic cover or the pulley? Does the H23A1 crankshaft pulley have any alignment mark? Last time when I went and look for with the timing light I couldn't find the alignment mark on my H23A1 crankshaft pully.
Old Jul 29, 2009 | 08:55 PM
Did you just read what we posted? The timing marks aren't on the crank pulley but on the flywheel. Look right were the tranny bolts to the motor. You'll see an engine code; H22A1 for example. Right above that there's a rubber plug that you need to remove to see the flywheel/marks.
dem0nk1d
Jun 27, 2012 12:39 PM
22boost
Oct 13, 2004 06:40 PM
EGHatchy
Jul 28, 2002 05:07 PM
bgod
Jul 23, 2001 06:37 AM
WONG FRIED RICE
Jul 9, 2001 02:25 PM
