Couple Problems 1 thread
Old Aug 3, 2009 | 03:00 PM
dirrtybirdy's Avatar
Default Couple Problems 1 thread
1. Squeeky doors (already tried to grease them up and it didnt even work)
2. Squeeky suspension.
3. AC sounds funny. Low rubbing sound when its on low to high.
4. Power steering sounds funny when turning at low speeds
Theres a couple of other things. Can I get some help please?
Old Aug 3, 2009 | 05:02 PM
teambk8's Avatar
Default Re: Couple Problems 1 thread
1. could be rubbing against the body panel when you open it
2. when?? always or just when you hit bumps?
3. is it on low or is it on high? rubbing sound, do you mean in the car or under the hood?
4. Have you checked the fluid?
also give us some info, is it an 81, 91, 01?? when do these things happen? what have you tried? if you greased the door where did you grease the lock or the hinge?
Thanks!
Old Aug 3, 2009 | 05:16 PM
1. Its not hitting any body panel. It just squeeks when you open and close it.
2. When im driving in the morning or when its cold.
3. When I turn the AC on it makes like a low "UUURRRRRRRRRRR" sound. from low to high.
4. fluid levels are good. it makes a whiny sound when turning in low speeds.
its a 98. sorry thought i posted that earlier.
Old Aug 4, 2009 | 10:35 AM
SixxT9's Avatar
For your AC... does it make that sound anytime the fan is on or only when the AC button is engaged?
ITR184
Apr 16, 2020 07:51 AM
Sammy24
Honda Civic (2001 - 2005)
Aug 19, 2018 01:18 PM
Blastersix
Honda Civic (2006 - 2015)
Nov 10, 2009 06:50 PM
EGSSdreamer
Aug 11, 2004 09:49 AM
