New H22, broken sensors!!
[IMG][/IMG]
what part is this? i just got my H delivered to day and saw this and the next pictures part is broken.
[IMG][/IMG]
this parts also broken, jus wanna know what they are so i can replace them. thx
[IMG][/IMG]
Re: New H22, broken sensors!!
yea.. the box one sits below the Intake Manifold, and is held on my 2 bolts.. has 2 hoses into the side as well as a connector.. and looks like it had 2 hoses on the other side as well... and i just bought a Blox Tps sensor off ebay.. hope they are good.
Just make sure you calibrate the TPS when you put it on. A quick search and you'll learn how.
yea for sure i looked in a swap book i had its called the "Vacuum Box" for the IAB.. havent really seen any for sale alone... checked ebay.. i didnt see any or i guess i suck at searching.
*(Just make sure you calibrate the TPS when you put it on. A quick search and you'll learn how)*
for sure, oh and if i get a P72 ecu i dont have to worry about the box do i? or do he Gsr's use the butterfly valves too?... i was told i can jus get the 72 and put an h22 basemap on it. ty for the help in advance.
u really dont need the vacuum canister or the butterflys.. they only help with very low rpm and daily drivin..if u dont hook up and vacuum to the butterflys they will run open all the time
Yes the GSR's use the dame style of IM. For the most part people get rit of the OEM manifold or if they keep it they end up removing the IAB's.
