What the Hell is Wrong?????Please
Old Jul 27, 2002 | 03:15 PM
flip1199's Avatar
Default What the Hell is Wrong?????Please
I got a 92 prelude si and its a stick and I leave it in gear when i park. This morning when i get in the car and start it up, its starts up fine. but while the clutch pedel is all the way in and the car is in gear the car starts moving forward. Also when the clutch was all the way in i couldn't get the damn thing outta 2nd gear. When i finally got it outta second, i was pushing the clutch pedal in and out but it wouldn't come all the way out. The pedal would get stuck and not come out. I looked and it wasn't caught on anything but just wouldn't come out. Also i noticed that it takes hardly any effort to push the clutch in now. I then let the car warm up for about 5 min, and tried putting it in gear but for the love of god it just wouldn't get into a gear. What the hell is wrong with my car??????
Old Jul 27, 2002 | 03:19 PM
laughinxxx's Avatar
New User
Default Re: What the Hell is Wrong?????Please (flip1199)
Well you either blew the clutch or your linkage is messed up. That's my guess.
Old Jul 27, 2002 | 05:58 PM
flip1199's Avatar
Default Re: What the Hell is Wrong?????Please (laughinXXX)
Anybody else got a guess???
Old Jul 27, 2002 | 06:04 PM
kevie88's Avatar
the clutch fluid was low and sucked in some air, or maybe the clutch master cylinder or slave cylinder are leaking somehow. I would say try bleeding the clutch and see what happens.
Old Jul 28, 2002 | 12:49 AM
flip1199's Avatar
Default Re: What the Hell is Wrong?????Please (kevie88)
Where the hell is the container for clutch fluid in my car??? i looked and all i could find was brake, windshield, radiator containers.
Old Jul 28, 2002 | 06:04 PM
BoostedH23a1's Avatar
i agree with kevie. its by your master cylinder resisovor (shut up i know i cant spell). the top right (drivers side) of the engine bay near the injector reistor.
Old Jul 29, 2002 | 10:55 AM
flip1199's Avatar
Default Re: What the Hell is Wrong?????Please (BoostedH23a1)
ok, it was the clutch fluid. I checked it and it was bone dry. I added some more, but is still dont work. How do i drain the old fluid? Or how else can i get it to work???
Old Jul 29, 2002 | 11:00 AM
LudeBehavior's Avatar
New User
it was bone dry and you added it in there....Now you have a realy big air bubble in there probally. did you make sure to pump the clutch while adding the fluid.
Old Jul 29, 2002 | 11:15 AM
flip1199's Avatar
Default Re: What the Hell is Wrong?????Please (LudeBehavior)
i was pumpin that bitch for a straight 5 mins, and nothing happened
Old Jul 29, 2002 | 11:32 AM
4bidden's Avatar
do a search and find out how to bleed the clutch.....that will fix your problem
Old Jul 29, 2002 | 12:28 PM
flip1199's Avatar
Default Re: What the Hell is Wrong?????Please (4bidden)
ok i did a search on how to bleed the clutch, but now i need to know where the bleed valve is on a 4th gen prelude????
Old Jul 29, 2002 | 12:53 PM
Boostless97Lude
Guest
Posts: n/a
my guess is it's on the front of the tanny (clutch slave cylinder)... you should see it, black think right in the front with a small hard line running to it. it should have a screw onnipple simialr to the brakes. just have someone pump on the clutch then hold the clutch in, then easy the nipple out a little at a time until fluid squirts out, then close it back off imediatley... that should eliminat the prob.... i hope
Old Jul 29, 2002 | 01:07 PM
bgod's Avatar
Default Re: What the Hell is Wrong?????Please (Boosted97Lude)
you have to bleed the fluid through your clutch slave. attached to the tranny. basically the same as bleeding brake fluid.
however, i'd try to concentrate on the system itself and see if you have a leak.
do you know exactly why you had no clutch fluid at all? is your master cylinder/slave still good.
it's just odd that you'd lose all your fluid.
by adding it and bleeding it, you may just lose it again.
Old Jul 29, 2002 | 02:13 PM
SUB-0 H23's Avatar
Default Re: What the Hell is Wrong?????Please (bgod)
check 4 leaks first... then add fluid and bleed it . im sure there is a leak. when u find it , fix the problem . you will prob have to change the slave cyl and clutch master, or rebuilt it ur self
Old Jul 29, 2002 | 02:14 PM
flip1199's Avatar
does anybody have a picture of these cylinders. I'm still pretty new to the prelude...
codybb4
Dec 9, 2008 08:44 AM
Hemix
11
Jun 30, 2008 11:25 AM
old_school_dohcvtec
Oct 4, 2007 09:47 AM
CWTegRNo.160
Jul 27, 2005 03:25 PM
92B20GSR
Mar 19, 2004 11:23 AM
