code 3... MAP SENSOR HELP!!!!
Old Aug 9, 2002 | 01:05 AM
crxtreme27's Avatar
Default code 3... MAP SENSOR HELP!!!!
Now i keep on getting code 3.. which is the map sensor.. i already did what the Helm's manual says... step by step and everything checks ok... the only thing i havent checked to is to replace for a good working known ecu... what else can i check for???
thanks
Old Aug 9, 2002 | 01:08 AM
PrecisionH23a's Avatar
Default Re: code 3... MAP SENSOR HELP!!!! (crxtreme27)
what did you do last to your engine/car before you threw this code?
Old Aug 9, 2002 | 01:57 AM
EH2DX's Avatar
its the black thing on the firewall right behind the intake manifold. it's held by a little bracket and there are wires hooked up to it.
Old Aug 9, 2002 | 06:31 AM
Smurfylude's Avatar
I you using a VAFC, that may be your problem. I had the samething happen to me, disconnected the MAP lines on the VAFC and no problems what so ever...
Old Aug 9, 2002 | 02:32 PM
prelude1897's Avatar
You may just need to get a new one
Old Aug 9, 2002 | 09:22 PM
EH2DX's Avatar
Default Re: code 3... MAP SENSOR HELP!!!! (Sushi X)
same here. i'm about to go re-do my wiring.... hopefully that will fix it.
eggie75
Apr 7, 2008 01:40 PM
sirhatch90
10
Jun 1, 2006 04:47 PM
Groove_D
May 27, 2006 11:40 AM
JasonST
Apr 26, 2006 07:36 AM
krz6jdm
Feb 21, 2006 01:36 AM
