dyno prelude???
Old Jul 25, 2002 | 01:01 PM
flip1199's Avatar
Default dyno prelude???
if i put on cam gears, fuel rail, fpr, would it be a waste of money taking it to a dyno??? i was thinking this way i can get a baseline hp, then once i turbo it i can see how much i added.
Old Jul 25, 2002 | 03:54 PM
Firedrake's Avatar
Default Re: dyno prelude??? (flip1199)
It's a good idea if you want to be able to see before and after turbo results, and you can tune the FPR and cam gears a little on the dyno if you're motivated to.....heck, make a run at stock fuel pressure, then one at -2 psi, then one at +2 psi and compare the results and post the runs up here (the -2 should give you the most power)
Brian
TreLude
Jan 16, 2004 09:52 PM
VTEC-DA
Mar 24, 2003 04:59 PM
fe519
Feb 5, 2003 01:47 PM
90accord1
Sep 12, 2002 09:25 AM
