Need help with H22a4 problem
Old Oct 22, 2002 | 07:05 AM
canuck-mx6's Avatar
Default Need help with H22a4 problem
My friend just swapped a 2001 h22a4 into his '92 Prelude SR (non vtec). He reused his old engine harness, but added the wires for the VTEC solenoid etc. He is using a 95 JDM H22 ECU (OBD1) with 95 H22 injectors (310 CC's, Peak and hold)
The car just isn't running right. It idles fine, but when you get on it, it stumbles and hesitates. Its as if it is not getting enough fuel. His fuel pressure is set to spec, and when we test the injector wires with a test light, we can see the light go on/off when the injectors fire. The injectors tick when they fire, but hardly any fuel comes out. The rail has fuel.
We think its either the ECU or the injectors, but the ECU fires the injectors.
Any help would be appreciated.
Old Oct 22, 2002 | 09:45 AM
Anubyss's Avatar
Default Re: Need help with H22a4 problem (canuck-mx6)
Have the a/f checked. You may need to have that adjusted and tuned. Probably going to need something like an Apexi vafc to control fuel.
Old Oct 22, 2002 | 09:53 AM
satan_srv's Avatar
Default Re: Need help with H22a4 problem (Anubyss)
Are you using the SR injector resistior box? Did you remove the H22A4 injector resistors?
Old Oct 23, 2002 | 12:14 PM
canuck-mx6's Avatar
Default Re: Need help with H22a4 problem (satan_srv)
Are you sure that the H22a4 has resistors, since it uses Saturated injectors?
Old Oct 23, 2002 | 12:36 PM
Anubyss's Avatar
h22a4 engine has no resistor assembly since it uses saturated injectors. I think he's saying he will need the resistor assembly to work with the peak and hold injectors that are being used.
Old Oct 23, 2002 | 02:51 PM
phildeez's Avatar
ne check engine lights? EGR? code 12 usually give you that bad bogging when you get on the gas.
Old Oct 24, 2002 | 10:59 AM
canuck-mx6's Avatar
What does the resistor box look like. I do not think that it was removed when we took out the H23, but I will double check.
Other than that problem, we have no codes or CEL
Old Oct 24, 2002 | 11:06 AM
satan_srv's Avatar
The resistor box is in the driver's side rear corner of the engine, a grey box with ridges on it. The injector signal from the ecu has to go through that resistor box before it gets to the JDM injectors. Is it set up that way?
Old Oct 24, 2002 | 11:44 AM
Anubyss's Avatar
[Modified by Anubyss, 3:44 PM 10/24/2002]
Old Oct 24, 2002 | 11:52 AM
satan_srv's Avatar
Ya like that! Except dirtier
Old Oct 24, 2002 | 11:54 AM
google's Avatar
check your map and tps make sure you dont have them switched so many people do that its amazing, when there switched the car will idle fine and when you hit it, it wont go anywhere fast
Old Oct 24, 2002 | 02:54 PM
MPower332TI's Avatar
Default Re: Need help with H22a4 problem (1320in11)
he said he used the 95 injetors..so it sounds like u need to wire in the resistor box...no big deal...i did mine on a 94 motor in a civic..if u need wiring diagrams let me know...
Old Oct 24, 2002 | 03:41 PM
R@mon's Avatar
Default Re: Need help with H22a4 problem (jDmDxTuRd)
if the car is a 4th gen the map sensor should be on the firewall but if the motor is a 2001 h22a4 then the map sensor is one the top of the throttle body. make sure it is connected to the one on the TB or if you want to use the one on the firewall, make sure it is connected to a good vaccum source....also check the TPS....
Old Oct 24, 2002 | 04:28 PM
satan_srv's Avatar
Default Re: Need help with H22a4 problem (93h22a4)
My 96 H22A1 has the MAP sensor on the TB....fyi
Old Oct 24, 2002 | 05:12 PM
Boostless97Lude
Guest
Posts: n/a
My 97 H22A4 has the MAP sensor on the firewall...
Old Oct 25, 2002 | 07:27 AM
R@mon's Avatar
Default Re: Need help with H22a4 problem (Boosted97Lude)
satn: i forgot that 96 and up where obd2. my fault.
boosted lude: i always thought that 5th gens had them on the body? what year did they change that? my cousin has a 97 and his is on his TB..
[Modified by 93h22a4, 8:31 AM 10/25/2002]
Old Oct 25, 2002 | 07:29 AM
Boostless97Lude
Guest
Posts: n/a
hehehe... i wasjust trying to thrwo some people off, b/c i've got the GM 3 bar map sensor, so i can run over 12 psi
Old Oct 25, 2002 | 07:32 AM
R@mon's Avatar
well it worked out great
Old Oct 26, 2002 | 04:51 AM
canuck-mx6's Avatar
Thanks for all the tips guys, I am on my way to the mechanics shop right now to get this sorted out
Old Oct 26, 2002 | 06:08 AM
BoostedH23a1's Avatar
o have a injector resister box if u need one.
Old Oct 28, 2002 | 02:34 PM
google's Avatar
Default Re: Need help with H22a4 problem (BoostedH23a1)
you dont need the resistor box unless your running 550cc injectors or higher. The conversion to high or low impedence is unecessary unless your making some serious power or have a rex with a jdm 91 b16. I have 320 no resistor box lude motor in a hatch. Im good never nedded nor added one o any of the 18 prelude swaps ive done. Except in a 01 accord with a 93 motor.
Acidcrakker
Engine Management and Tuning
Mar 17, 2012 05:38 AM
wburke69
Aug 9, 2010 09:19 AM
nexgen91
May 15, 2004 08:53 PM
RaCk
Feb 10, 2004 06:10 PM
