the OFFICIAL TURBO Prelude thread!!!
Guest
Posts: n/a
the OFFCIAL TURBO Prelude thread!!!
ok, after seeing topic after topic of the same stuff, i figured it might just be a good idea to start a thread here that is specifically for Turbo Prelude questions.
i am hoping for good response's from anyone that knows anything about turbo Prelude engine, specifcally the H22, and H23.
so...... ask away.
EDIT: i am NOT trying to say i know it all, i still have a lot of turbo questions myself, but i am hoping that with everyone else that knows about them, we could have a kick *** "collective intelligence"
[Modified by Boosted97Lude, 2:26 PM 10/25/2002]
so...... ask away.
Re: the OFFCIAL TURBO Prelude thread!!! (Accord94DX)
Ok, as far I know the h22a series engine is not a good engine for turbo application, the GSR is better. I believe this thought is based on the pistons in the H22A, and there weakness?
[Modified by RY8127, 11:40 AM 10/25/2002]
Guest
Posts: n/a
Re: the OFFCIAL TURBO Prelude thread!!! (RY8127)
i have only heard a few stories about people being able to boost over 8 psi on stock H-series internals. the ringlands can't take the pressure, and even if you put in forged pistons it has to be re-sleeved (at least on the H22A4), due to the material the sleeves are made of.
Re: the OFFCIAL TURBO Prelude thread!!! (Boosted97Lude)
Ok, i gotta question for the boost guru's.. I am planning on running a garret t3/t4e but have yet to decide on a manifold... can anyone suggest a manifold that is a/c compatible as well as give me enough clearance from the block to mount the turbo.. (i live in miami and therefore losing a/c is not an option)
Re: the OFFCIAL TURBO Prelude thread!!! (LordVtec)
http://www.maxrev.com
GREAT MANIFOLD NEVER HEARD OF ANY PROBLEMS.... I have one and the quality is amazing and im running a T3/60-1
[Modified by DS1, 7:02 PM 10/25/2002]
I have heard the same thing about the SFP manifolds.. i was considering them because they are local and we used an sfp manifold on a b16 we built.. but i have heard that their h series manifold sucks.. i am probably going to go with the maxrev manifold and downpipe.. havent heard any complaints as of now..
I am going to have to look into fmax as well... i kinda like the maxrev so far.. but i havent really looked into Fmax yet.. gonna check them out first before making my decision..
The H series manifolds from SFP will work fine if you're using a smaller compressor housing (like a T04b.....dunno who would run a T04b on a prelude motor though ) but with a T04e you need to lose one of your motor mount bolts and trim the heck out of the block, which in my eyes is unacceptable......I'm in turbo limbo right now, because I was planning to upgrade to a GT3240, but now I don't know what I'm going to do.....our shop got a lot of work all the sudden, so the prelude turbo project is just kinda waiting.......
Anyways, don't get the SFP manifolds for the H series, there are better manifolds available, especially for what they charge.....their B and D series manifolds are great though! I'm going to be sending the 2 H series ones we got back to them to be redone with the flanges at a different angle and cleaner welds (the welds on my manifolds are AWFUL!)
Brian
P.S. Apexii, did you ever end up getting one of the VRS exhausts from paul? I ordered mine and it's been over a month and still no exhaust, just curious......
Brian
Re: the OFFCIAL TURBO Prelude thread!!! (Firedrake)
Any graphic artists reading this??
Re: the OFFCIAL TURBO Prelude thread!!! (714)
Only response I've gotten from Paul so far was "you should be getting it soon, I will try to get you a tracking number ASAP" and that was on Monday......owell, not like I can use it until I'm ready to install the turbo stuff anyways.....a 3 inch N/A exhaust would probably be even more obnoxious than my 2.25 inch I'm running right now
Brian
Brian
trade u gude for my t3/t4 b
ITS NOT THE H22/H23 PISTONS THAT ARE WEAK. its the ring landings..
for the most part 7 psi is fine on stock bottom end. ive seen a few h23s that are properly tuned runnin 11psi daily. but i really wouldnt reccomend it... say with 7ish. make sure u have enough fuel...and your timing isnt advanced much if at all.
Guest
Posts: n/a
Re: the OFFCIAL TURBO Prelude thread!!! (BoostedH23a1)
ok, just thought i'd throw out this comment... after hour of using the cutting torch, and the Dremel tool (talk about complete opposites), i have my everything to mount my GReddy type 24 FMIC. the IC itself is semi attached to the crash bar already, but not with any bolts yet. as opposed to what most people with a type 24 do, i modified my crashbar rather than removing it. i hacked a lot of it off, but now i am going to start making measurements and weld some reinforcements to it with the use of some roll bar tubing. i just thought i'd throw that out for you guys, i'll post some pics up tomorrow when i get to work.
dude you gotta post some pics when you are done.. i think i am going to run into the same issues with the crash bar when i install my spearco...
Guest
Posts: n/a
some of the torched spots look kinda mangled right now, but i haven't had the chance to hit em with w/ a grinder yet, but i'll give you some pics tomorrw anyways
BTW, if my body kit wasn't bigger than my OEM bumper, this most likely wouldn't have worked
Guest
Posts: n/a
well, i'm not sure about that, the type 24 i've got is like skyline gt-r sized, i mean, that thing is HUGE. i don't think the spearcos are as big, but i could be wrong. i've got a spearco sitting in my shop that's off my buddies civic, and mine is almost twice as big
i have a spearco, 29 inches long, 3 inches thick, and 7.5 inches tall.. gonna post a pic.. gimmie a sec
[Modified by LordVtec, 1:43 AM 10/26/2002]
Looks a lot like mine, I'll try and post some pix tomorrow while I'm swapping my EGT gauges.....mine is a 24x3.5x8 spearco core and another 2 inches or so on each end for the endtanks......I haven't even started doing fitment yet, but it should fill in the bigmouth bumper pretty well......how hard is that front impact support to cut? I have to keep it, because my bumper will sag under it's own weight without the support.....
Brian
Brian
New User
Guest
Posts: n/a
Re: the OFFCIAL TURBO Prelude thread!!! (SilverLudeSi)
alrighy, my FMIC is 11" tall, by 30" wide (endtank to endtank), by 3" think
yeah, like i said, the torched areas are kind rough, i should got my dad to to it, he's like 50 times better at it than i am, but i'll take to it with a grinder and clean that up.
