installing intake ?
Old Oct 23, 2002 | 07:46 PM
crackhead's Avatar
Default installing intake ?
wonderin if theres anything else i need installing aem cold air intake
except for wats in the instructions
Old Oct 23, 2002 | 07:57 PM
vicz's Avatar
Default Re: installing intake ? (crackhead)
nope, as long as you have new clamps and what not, you should be fine.
Old Oct 23, 2002 | 10:24 PM
1-Bar's Avatar
AEM CAI on a 4th Gen, nothing special. However on a 5th Gen you will need to cut a bigger hole out of the exsisting one. The AEM CAI was designed for the 4th Gen's which has a bigger hole for which the resinator is under. Apart from that its pretty much smooth sailing.
GL
Old Oct 23, 2002 | 10:33 PM
stoopid215's Avatar
Default Re: installing intake ? (1-Bar)
hrm would it be easier to pay a shop to install my aem cai (arriving soon from coximport)? i got a 5th gen and i dont feel like doing the drilling...and would they know that it has to be drilled bigger?
Old Oct 23, 2002 | 10:35 PM
SpeedGyrl's Avatar
Default Re: installing intake ? (stoopid215)
I had a friend put my intake in. He made the hole larger, but he didn't have to use a drill. It isn't that hard to install. I wouldn't pay someone to do it.
Old Oct 23, 2002 | 10:38 PM
stoopid215's Avatar
Default Re: installing intake ? (99LudeGyrl)
how'd he make the whole larger w/o drilling?
Old Oct 23, 2002 | 10:40 PM
SpeedGyrl's Avatar
Hammer... and no it didn't screw it up... suprisingly
Old Oct 24, 2002 | 03:07 AM
munscher's Avatar
GL
You have to widen the hole on a 4th gen as well, installed my AEM CAI two weeks ago. I just used a dremel to cut it a little larger. Do it yourself man, its incredibly easy. Take the old one out, put the new one in, tighten a few clamps and you're done.
Old Oct 24, 2002 | 09:18 AM
Ludester's Avatar
Default Re: installing intake ? (munscher)
did the same thing dremel to open the hole about an inch. Other then that it is rather simple. On the vtec model its a little harder. Then the s or si.
LudeAchris2001
Oct 21, 2003 08:33 PM
drewha174
May 8, 2003 08:09 PM
wadafa
Jan 2, 2003 11:27 PM
WheAs MaI MojO
Dec 5, 2002 05:30 AM
Mike95lude
Aug 19, 2002 12:11 PM
