valve timing
Old Oct 28, 2002 | 11:18 AM
SH LUDE's Avatar
Default valve timing
My friend told me my valve timing on my prelude was messed up, and he said he could fix it. Is it a easy process to re-align valve timing? Thanks
Old Oct 28, 2002 | 01:31 PM
DirtyLude's Avatar
Default Re: valve timing (95 Prelude SI)
Unless your timing belt has skipped a tooth or you have adjustable cam gears, then your valve timing is fine. If you've skipped a tooth, you have more to worry about than just the current valve timing.
Changing valve timing on our engine without adjustable cam gears is impossible without offsetting the teeth from the timing belt, which is not an option.
Old Oct 28, 2002 | 02:16 PM
4bidden's Avatar
Default Re: valve timing (DirtyLude)
he probably meant a valve adjustment whic is relatively easy if you have the right tool
Old Oct 28, 2002 | 02:17 PM
DirtyLude's Avatar
Default Re: valve timing (4bidden)
Yes, that's probably what he meant. I should have thought of that.
Old Oct 28, 2002 | 08:14 PM
SH LUDE's Avatar
thanks, but any idea how to do it?
I don't want to see my friend **** up while me and him are doing it and then I get stuck w/ a big *** bill on my hands after
thanks again~!
Old Oct 28, 2002 | 08:22 PM
DsITR's Avatar
It's called valve lash adjustment..Get a Helms manual It is invaluable. If you want I could email you the chapter, to walk you through it.
lemme know.
n'vermind, sorry...your car is an SI, mines 5thgen H22a4, wouldn't be the same..
[Modified by dsludefosho, 10:23 PM 10/28/2002]
journeyquest
Jul 10, 2011 12:34 PM
NokStrImpz
Mar 28, 2008 09:10 PM
euG3dc2r
Feb 23, 2005 03:45 AM
555R
Jan 11, 2005 05:46 PM
