bad compression
Old Jun 23, 2003 | 09:12 PM
thehondaguru's Avatar
Default bad compression
did a comp check cause I want to spray. Car has close top 100000 miles on it and #1 cylinder is about 20 psi lower than the rest. Just wondering if changing the head gasket would help the compression out at all. Also would the valves needing adjusting have something to do with it. Just wondering because i hope I dont have to changed the rings. Thanx
Old Jun 23, 2003 | 09:25 PM
JG Luder's Avatar
Default Re: bad compression (95 lude)
Valdosta. My dad is a dept head at VSU there.
Anyway... a head gasket is most likely not your problem. Rings are where I'd start.
The best thing to do is have a shop run a leakdown test. The air will go somewhere. Usually under 10-8% leakage is acceptable. Listen for where the air goes and hisses. If it comes out the exhaust, it's an exhaust valve. If it's out the intake, then it's an intake valve. If it comes out the crank case breather tube, then it's your rings.
Or you could run a wet compression test. This involves tossing a few capfuls of oil in the cylinder that is low. If the numbers increase, then it's more than likely your rings.
Old Jun 23, 2003 | 09:29 PM
Default Re: bad compression (Lone Luder)
Thanks I will do a wet comp test and if no difference I'll do a leak check at some place thanks man. Oh and Valdosta sucks...Hardly any luders
Old Jun 23, 2003 | 09:55 PM
JG Luder's Avatar
Valdosta isn't that bad. The few times I've been there though I've seen some retarded ricers. Then again, their everywhere.
You should try Birmgingham. It's hard to tell what's fast and what isn't. Some of the gheyest cars might whoop your ***.
Now, Troy? Where I AM right now? Dear Lord. Farm Truck nationals. I gotta get outta this place.
Old Jun 24, 2003 | 07:41 AM
you got that right the ricers get worse and worse every day here. but yes there is "some" fast cars
bvillarreal
Aug 22, 2013 09:43 PM
KRZRICAN
Apr 30, 2009 07:35 PM
MrMug3n
Jul 11, 2008 07:13 PM
Hcivic88
Jun 12, 2003 11:45 AM
foesicks
Jan 8, 2003 03:16 PM
