Mechanical issues ... NEED HELP !!!!!!
Old Jun 21, 2003 | 02:31 PM
2nd Gen BlkDrgn's Avatar
Default Mechanical issues ... NEED HELP !!!!!!
Found ugliness in my 2G Lude.
A friend told me that my Lude blows out Blue/White smoke when driving.
I smell fried oil occasional but the oil pressure is ok, the oil level does not change from week to week and the car temp is stable .... please help ASAP!!!!!!
Old Jun 21, 2003 | 02:55 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Mechanical issues ... NEED HELP !!!!!! (2nd Gen BlkDrgn)
you need to do a compression test and a leakdown test
does it smoke more at high rpms or low???
high rpms usually means bad rings
low rpms usually means bad valve seals
Old Jun 21, 2003 | 08:01 PM
Default Re: Mechanical issues ... NEED HELP !!!!!! (Boosted97Lude)
It starts at 3500 RPM plus and comes out of the tailpipe like a tornado motion.
What does a compression and leakdown test bnormally run?
Someone told me it may be a head gasket, how much truth is in that?
Old Jun 22, 2003 | 10:26 PM
Found no Water in the Oil so I'm not to sure its the Head Gasket.
Are there specific places that I should take my Lude to do the Comp. & Leakdown Test or is this a normal mechanic shop thing?
Old Jun 23, 2003 | 04:01 AM
Boostless97Lude
Guest
Posts: n/a
for the comp and leakdown test i woudl suggest taking it to
A) a reputible shop in your area
B) Honda
mr2passat801
Aug 15, 2010 08:16 AM
Typeron
Jan 5, 2006 07:37 PM
revlimitx04
Nov 22, 2005 01:11 AM
HONDA@HEART
Aug 26, 2005 09:51 AM
fivezigen858
Jul 12, 2001 12:56 PM
