Headlight relay
Old Jun 27, 2003 | 02:13 PM
optikal_blitz's Avatar
Default Headlight relay
I think i have a blown headlight relay.
My symptoms:
When light switch is set to low beam-
Pass. Side light is on normally..but with a dim high beam, Driver side low beam <u>and</u> high beam come on dimly (half way lit, even)
When high beam is active-
Pass. Side light is on highbeam (as its supposed to) but with a dim low beam, Drivers side completely out.
If it's not the relay, what could it be? Someone please toss me some info, cause it's making for some very unsafe night driving.
edit::
-corrected symptoms.
-checked fuses
-checked bulbs (all work)
-this is a 4th gen.
Modified by NatakuBlitz at 8:15 PM 6/27/2003
Old Jun 27, 2003 | 02:35 PM
Elkins911's Avatar
Default Re: Headlight relay (NatakuBlitz)
did you check the fuses. when a fuse gets blown the light come on dim too.
Old Jun 27, 2003 | 05:11 PM
bump cause i wanna drive at night..
Old Jun 28, 2003 | 07:14 AM
Default Re: (NatakuBlitz)
back up top.. help!
Old Jun 28, 2003 | 12:26 PM
Elkins911's Avatar
bump.... someones gotta help him out.
Old Jun 28, 2003 | 04:21 PM
Default Re: (Elkins911)
thanks man..this is killin me- bump to the fullest!
Old Jun 29, 2003 | 08:41 AM
up we go again.
Old Jun 29, 2003 | 04:01 PM
ill trade someone my JDM ITR Recaros for the solution.
pr1madona
Honda CR-V & Element
Oct 1, 2016 11:52 AM
Kohen
Oct 14, 2011 08:44 AM
rice a roni
Jan 2, 2009 06:44 PM
95lscivic
Jan 14, 2008 08:31 AM
jdm4dr
Apr 16, 2003 10:34 AM
