check engine light and atts light
Old Jun 24, 2003 | 02:32 PM
morxican's Avatar
Default check engine light and atts light
I have a v-afc and after it was installed and dyno'd these lights keep comeing on. The honda dealership said they come on with low oil. I checked my oil and its fine. The code that the engine light puts out talks about the v-tech solonoid. Could my v-tech solonoid be bad or is my v-afc messing up my car? Its a 98 prelude type sh h22. Any help would be great. Has anyone ever seen this problem before?
Old Jun 24, 2003 | 04:10 PM
wildesh's Avatar
Default Re: check engine light and atts light (morxican)
did you connect the VTM wire.
Old Jun 24, 2003 | 05:25 PM
el_Presidente's Avatar
VTEC
Old Jun 24, 2003 | 07:52 PM
morxican's Avatar
Default Re: check engine light and atts light (el_Presidente)
i dont think it had a vtm wire.
Old Jun 24, 2003 | 09:44 PM
Behan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by morxican &raquo;</TD></TR><TR><TD CLASS="quote">i dont think it had a vtm wire.</TD></TR></TABLE>
It should have, go to http://www.apexi-usa.com, the instructions are under documentation. If you did the install yourself recheck your wiring, etc. If a shop did it take it back to them and MAKE them fix it. you need to hook up the VTM wire.
Old Jun 25, 2003 | 01:54 PM
morxican's Avatar
Default Re: check engine light and atts light (93preludevtec)
Thanks for the apexi web site. It had a correction to the manual that came with the controller. My car has a vtm signal on the sites corrections, but the manual said it didnt
Old Jun 25, 2003 | 02:53 PM
Behan's Avatar
no prob, glad you checked the corrections yourself as i forgot to put that in my post.
Old Jun 25, 2003 | 07:49 PM
morxican's Avatar
I just hope the shop that installed it will connect the wire. With out charge. Any way Thanks for the help.
Old Jun 25, 2003 | 07:52 PM
Behan's Avatar
if they don't report them to the better business bureau, and IMO i wouldn't take your car there anymore if they couldn't handle this simple install.
b20vtech
Aug 29, 2006 08:48 AM
vthree
May 6, 2006 03:56 PM
soon2b
May 22, 2005 06:39 AM
95LSDOHC
May 5, 2004 09:43 PM
