header modification update ...
Old Jun 13, 2004 | 03:45 AM
Inextricabledrvr's Avatar
Default header modification update ...
well as you all know, DC header sucks *** the way it is. But i had it modified this past friday with a 2.5" from the collector and it made the biggest difference in midrange to high end power. I couldnt believe it.
Also to test it out, my friend has a base with just a flywheel, intake, and a high flow cat and he always used to pull me instantly. Now were head up till 70 and then i start pullin on him !! Were both excellent drivers, we even switched cars to see if it was the driver, but no the same thing. My friend was surprised.
Who says a DC header is a POS? I believe not....
I currently have:
Apexi world sport with a carsound high flow cat.
Dc header (modified) (unbelievable gains)
aem pullies
aem short ram
FPR@40PSI
Old Jun 13, 2004 | 06:11 AM
Kal's Avatar
Kal
Default Re: header modification update ... (Inextricabledrvr)
it's a POS compared to a SMSP
Old Jun 13, 2004 | 06:52 AM
PirateMcFred's Avatar
well V8's are piles of Sh*t until you go with nice rods, balanced bottom end, higher compression and ported heads and fuel injection and hearders and then spray NOS... the point is that DC headers are POS's out of the box. Not eveybody is all about spending $300 on something that they have to chop up and make better.
Old Jun 13, 2004 | 07:09 AM
AndyD's Avatar
How much did it cost to have it changed and who did it for you??
Old Jun 13, 2004 | 07:39 AM
SUB-0 H23's Avatar
good to here bro , only if you had dyno graphs.
Old Jun 13, 2004 | 09:07 AM
hOndafienD 04's Avatar
what motor was this done on? h22 or h23?
Old Jun 13, 2004 | 09:21 AM
Rick Solis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">it's a POS compared to a SMSP </TD></TR></TABLE>
Couldnt have said it better myself...
for a low budget mod it'll help some but theres still so many downsides to the DC header as a whole, not just the collector diameter...
The pea shooter primaries arent very useful, the 4-2 transition leaves much to be desired, etc, etc...
I mean, if you have the DC already than why not, but as a save all for the average joe looking for a good performance header... there are better options
Prospeed/AN-R, Imagine Engineering, Hotshot, etc...
Old Jun 13, 2004 | 10:24 AM
Default Re: (hOndafienD 04)
i will be dynoing within the next few weeks to show what i have gained...
Old Jun 13, 2004 | 10:25 AM
Default Re: header modification update ... (AndyD)
i spent $100 on a muffler shop out here...
and i got the header used off a friend of mine for $60....so total i spent about $160
Modified by Inextricabledrvr at 12:13 PM 6/13/2004
Old Jun 13, 2004 | 10:26 AM
h22a4
Old Jun 13, 2004 | 10:32 AM
im thinking about dc headers, and straight pipe from the collector till after the resinator...so basically removing cat and resonater on my h23....
Old Jun 13, 2004 | 10:42 AM
sounds good..i didnt remove the cat because i didn't want that raspy honda sound that it would make.
also make sure your flexpipe is the same size as all your piping from the collector back ....If your 2.5" use it all t he way back...and thats where i noticed it the most...i will have dyno graphs posted within the next few weeks to show how much i gained overall...
goodluck
Old Jun 13, 2004 | 01:45 PM
Nikoli's Avatar
Default Re: (Inextricabledrvr)
i've been thinking about doing this too since i already have and didnt spend 300 on it.
:waiting for the dyno:
Modified by 95deckedlude at 4:25 PM 6/13/2004
Old Jun 13, 2004 | 02:43 PM
VTECRaZeR's Avatar
Default Re: (95deckedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95deckedlude &raquo;</TD></TR><TR><TD CLASS="quote">i've been thinking about doing this too since i already have and didnt spend 30 on it.
:waiting for the dyno:</TD></TR></TABLE>
ditto
I been thinking about doing that, but may be I'll go a step further and do it with a greddy header....I will like to see the dyno too first.
And with that carsound high flow cat did you pass smog here in Cali?
team714
Sep 10, 2008 09:54 AM
samsong
Aug 21, 2007 09:37 PM
DANG YO
Jan 5, 2005 01:50 PM
Hyjnx
Dec 9, 2004 06:19 AM
93superchargeredcivicex
Nov 24, 2001 08:56 PM
