No Vtec No codes
Old Jun 6, 2004 | 05:51 PM
Quade's Avatar
Default No Vtec No codes
Is it possible for your vtec not to engage and yet not a code/check light? If so what are some of the conditions? Assume turbo motor, good ecu and working check light.
crdcz03's Avatar
Fortune Cookie Member
Default Re: No Vtec No codes (Quade)
the first thing anyone should do if their vtec doesnt work is check the oil lol
seems to happen to my sister quite a bit
Old Jun 6, 2004 | 07:25 PM
Turbogixxer's Avatar
Default Re: No Vtec No codes (crdcz03)
Then check the soleniod itself and the screen for it too.
Old Jun 6, 2004 | 08:20 PM
5hif7's Avatar
Default Re: No Vtec No codes (turbogixxer)
I have always been wondering, how would I get to the solenoid and the screen to clean it out?
Old Jun 15, 2004 | 09:57 AM
5hif7's Avatar
Default Re: No Vtec No codes (5hif7)
can neone help me out with this?
EDIT: nm, I found it in Helms, this thing kicks ***
Old Jun 15, 2004 | 10:14 AM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quade &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible for your vtec not to engage and yet not a code/check light? If so what are some of the conditions? Assume turbo motor, good ecu and working check light. </TD></TR></TABLE>
to answer your question, yes, vtec can not engauge and not set a code. there are certian requirements for vtec to engauge, if one is not met that does not mean the car has a huge problem, it just might mean theres low oil , cars not warm enough , not enough throttle position measured, etc,
Old Jun 15, 2004 | 10:27 AM
Speedra500's Avatar
Default Re: No Vtec No codes (prelittlelude)
you also want to check the wire connection to the solenoid, I know mine has fallen out a time or 2, always seems to be when I race someone too....
EGThang
18
Jun 6, 2008 03:26 PM
greencivic1029
Sep 2, 2005 08:57 AM
veilsides2000
Nov 27, 2004 11:18 PM
grlstockb18c1
Nov 3, 2004 07:07 PM
brian2903
May 2, 2004 12:10 PM
