Fast Idle
Old Jun 9, 2004 | 03:56 PM
delguiner's Avatar
Default Fast Idle
Can someone please show me a diagram or a pic of wher e the fast idle valve is.. ive been having bouncy idle now... not only when cold, but now when its wartm the car it still happens... thanks!
Old Jun 9, 2004 | 06:29 PM
LudeSi707's Avatar
Default Re: Fast Idle (delguiner)
yeah i have the same problem with my lude and i to dont know where the fast idle thermo valve is located...
Old Jun 9, 2004 | 06:32 PM
crdcz03's Avatar
Fortune Cookie Member
Default Re: Fast Idle (LudeSi707)
under the throttle body
you can take it off without taking the throttle body off, but its a lot easier with the TB off than on.
theres 3 bolts (10 or 12mm) and a hose or two connected to it, just take those off/out and replace with the new one or just take it apart and pull the spring inside it apart like 3/4-1 inch and put it all back together. then say goodbye to teh infamous-pain-in-the-***-wake-the-neighbors idle lol
Old Jun 9, 2004 | 06:41 PM
delguiner's Avatar
Default Re: Fast Idle (crdcz03)
aren't you talking about the IAC Valve?
Old Jun 9, 2004 | 06:55 PM
LudeSi707's Avatar
does anyone know for sure that its the fitv because ive been changing alot of things like my map sensor and my idle air control valve and it still idle like crazy...
Old Jun 9, 2004 | 07:00 PM
delguiner's Avatar
If you have an 92-96 Si/SR its that for sure...
i heard its a really common problem with the H23
crdcz03's Avatar
if it hasnt fixed it yet... id put $50 on the FIV fixing your problem (btw i dont have $50 lol)
Old Jun 9, 2004 | 07:04 PM
delguiner's Avatar
dude where is it? are you sure your not talking about the IAC valve???
Old Jun 9, 2004 | 07:25 PM
LudeSi707's Avatar
kool yeah cause i have an 93 si and ive spent so much money on the wrong things
Old Jun 9, 2004 | 07:39 PM
delguiner's Avatar
ya im pretty sure its that
now to find out where the Fast idle valve is located
Old Jun 9, 2004 | 07:44 PM
crdcz03's Avatar
i just posted this somewheres else... look around this page or the 2nd page for another thread like this
Old Jun 9, 2004 | 07:54 PM
delguiner's Avatar
and its easy to get to without removing it? what does it look like?
Old Jun 10, 2004 | 01:10 AM
Hawkze_2.3's Avatar
It's technically called the Fast Idle Thermal Valve because it's activated by heat with the wax it has inside...It's right on the bottom of yout throttle body-attached to it...Just block it off...
I did all this IAC and FITV stuff and none of it fixed my crazy idle, but replacing the intake manifold gaskets did fix it for good...they get soaked in oil from the PCV valve...
Old Jun 10, 2004 | 06:03 PM
jsw1gga1's Avatar
Default Re: Fast Idle (Hawkze_56)
yup the post are right.its the fast idle control valve.happened to me before.what i did was checked all hoses for leaks and replaced the valve and reset the computer.bye bye crazy idle!
protopro88
Apr 8, 2011 03:41 PM
Acemcguyver
Classic Hondas
Jun 2, 2008 01:39 AM
CRX-SIR
Sep 20, 2004 06:00 PM
B16Hatchcx
Apr 26, 2003 11:40 AM
TurboCRVTEC
Oct 9, 2002 05:38 AM
