Lightweight Battery
Old Jun 18, 2004 | 12:52 AM
Demonlude's Avatar
Default Lightweight Battery
What lightweight dry cell battery is anybody using? Just been looking at the Odyssey batteries, but I'm not sure which model I would need. Would it be the PC545 or PC625?
http://www.batteryweb.com/odyssey.cfm
Old Jun 18, 2004 | 01:03 AM
bad-monkey's Avatar
Default Re: Lightweight Battery (Demonlude)
i'm using the hawker genesis G16 battery. not sure which odyssey battery that is, but they do make one that is exactly the same unit, different stickers.
Old Jun 18, 2004 | 01:10 AM
@ries's Avatar
I'm using the NRG/Heeltoe battery... it's very light weight.
https://honda-tech.com/zerothread?id=860330
Old Jun 18, 2004 | 03:57 AM
Demonlude's Avatar
Default Re: Lightweight Battery (@ries)
What's the weight of the NRG battery. Less than 12lbs?
Old Jun 18, 2004 | 06:14 AM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonlude &raquo;</TD></TR><TR><TD CLASS="quote">What's the weight of the NRG battery. Less than 12lbs?</TD></TR></TABLE>
most lightweight batteries are about 13.2 lbs. they all weigh the same since they're all basically the same battery, repackaged and sold by whomever.
Old Jun 18, 2004 | 07:10 AM
Kal's Avatar
Kal
Default Re: Lightweight Battery (bad-monkey)
is life significantly less for a lightweight battery or is it better/same?
Old Jun 18, 2004 | 07:12 AM
Daemione's Avatar
You'll want to check out the temperature ranges for whatever battery you're looking at. I believe the 545 has less tolerance for high temperatures, which wouldn't be any good for an underhood installation.
Old Jun 18, 2004 | 08:34 AM
bad-monkey's Avatar
Default Re: Lightweight Battery (Daemione)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">You'll want to check out the temperature ranges for whatever battery you're looking at. I believe the 545 has less tolerance for high temperatures, which wouldn't be any good for an underhood installation.</TD></TR></TABLE>
yeah most lightweight SLA batteries do not thrive in high temps. they last maybe a year in those conditions. if relocated to the trunk, they'd last 5+
Power Rev Racing
60
Dec 14, 2005 09:09 AM
redciv
Aug 20, 2002 09:37 AM
