Clutch Alignment Tool
Old Jun 16, 2004 | 02:02 PM
lildrgn2.0's Avatar
New User
Default Clutch Alignment Tool
Ok. I am trying to put the last bit of this pain in the *** engine together. I am down to the clutch and tranny. I have gone to Autozone, napa, and Advance Auto (all the local stores around here), and no one has one for the h22. I called Honda and they said that I would have to find what the tool part number is so they could order it.
What the hell? How do I put the clutch on with out the tool? IDEAS... HELP!
Old Jun 16, 2004 | 02:09 PM
PetroGuyX's Avatar
can you not use the same one as the h23?
Old Jun 16, 2004 | 02:29 PM
rjr162's Avatar
Default Re: (PetroGuyX)
See if someone has the one that came with the aftermarket ACT clutch or something. Someone has to still have it laying around.
Old Jun 16, 2004 | 02:43 PM
Speedra500's Avatar
Default Re: (rjr162)
Hey Mike, It's Eric, you know the one that was over there helping you with the fiberglass, I think I've got a few clutch alignment tools lying around, I can swing by there and help you out whenever
Old Jun 16, 2004 | 03:50 PM
bigchevy66's Avatar
Default Re: Clutch Alignment Tool (Lildrgn)
Are you talking about the little plastic alignment tool that comes with a new clutch? If so, those things are a piece of crap. I used one when I did the clutch on my '68, and the input shaft still didn't line up. I've heard this from numerous people also. The best thing to use is an old input shaft to line everything up with.
I'm sure you've done this, but take your clutch assembly and slide it onto the input shaft of your tranny just to make sure everything will go together fine. Good luck. John
Old Jun 16, 2004 | 05:29 PM
v4lu3s's Avatar
RTFM
i use an old input shaft, an alignment tool if the clutch kit came with one, or a ratchet handle.
BigAnteg
12
Jun 4, 2010 01:22 PM
tacchan
26
Mar 17, 2010 11:25 AM
RTW DC2R
Feb 11, 2005 04:37 PM
fastlude69
Jul 14, 2004 07:12 PM
