H22A7 Data & Specs needed
Old Sep 7, 2004 | 03:29 PM
modifications's Avatar
Default H22A7 Data & Specs needed
im rebuilding my engine. its a 1999 H22A7 ( UK Accord Type R )
i need to know the clearances for oil and also crank sizes etc. rod housing sizes, bearing sizes.
i could do with as much info on the block ( bottom end ) as possible to make sure its all in tolerance.
My engine is the same as the prelude H22A1.
I think im going to order Toga bearing combo ( Main & Rod ) but I was told that the H22A has colour coded bearings etc. and I would need to check to make sure I don’t need over size.
Any help please !
Old Sep 7, 2004 | 03:55 PM
satan_srv's Avatar
Default Re: H22A7 Data & Specs needed (modifications)
can you not purchase a shop manual for the car? it has all this info and more...
I would tell you the info from my Helms manual but I have the 95 H22a1 manual and you are incorrect that an H22A7 is the same as an A1...it like a 98+ H22A4 as both motors have larger crank mains (55mm vs. 50mm) than the H22A1, they are also Open deck etc.
For block info you want to be looking at an H22A4
Old Sep 8, 2004 | 01:08 AM
pentaq's Avatar
Default Re: H22A7 Data & Specs needed (satan_srv)
I have one but in Polish. I could translate it for you if you want. Just give me all the things you need to know (mail, pm whatever)
Old Sep 8, 2004 | 01:13 PM
Default Re: H22A7 Data & Specs needed (pentaq)
going to get a Helms manual
cheers for the help
uberEFtuner
Dec 14, 2014 04:33 PM
Quade
Mar 14, 2009 05:05 PM
pip9
10
Jun 26, 2004 02:08 AM
ranta18
Apr 27, 2004 02:56 PM
VanHonda
Sep 16, 2003 09:33 AM
