High Idle
Old Sep 6, 2004 | 03:02 PM
Chinchilla's Avatar
Default High Idle
My 93 SR seems to be idleing very high latley, I've tried removing and cleaning the air intake control valve with no luck. I've tried adjusting the screw on top of the throttle body, but as soon as I drive the car it idles back at 1,100-1,500 RPM
this came about the same time as I took my Zex kit out but I dont know how that could effect the idle.
Anyone have any ideas?
Old Sep 6, 2004 | 08:04 PM
Chinchilla's Avatar
Default Re: High Idle (Chinchilla)
bump
Old Sep 6, 2004 | 08:09 PM
aquarius's Avatar
Thats not THAT high. my car sometimes idles at 500...so you should be lucky you dont have the opposite problem. It might have to do with oil pressure, or coolant though.... Check the ecu codes.
Old Sep 6, 2004 | 09:09 PM
Chinchilla's Avatar
Default Re: High Idle (TPreludeSi)
none the less its not the right idle speed... if your car is idleing at 500 you should adjust it.
my whole coolent system as been replaced latley, I tried to check the bleeder screw on top of the thermostat but I didn't seen any coolent. should it be flushed and filled?
Old Sep 6, 2004 | 09:34 PM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chinchilla &raquo;</TD></TR><TR><TD CLASS="quote">none the less its not the right idle speed... if your car is idleing at 500 you should adjust it.
my whole coolent system as been replaced latley, I tried to check the bleeder screw on top of the thermostat but I didn't seen any coolent. should it be flushed and filled?</TD></TR></TABLE>
Nothing came out when you loosened it?
Old Sep 7, 2004 | 03:37 AM
Chinchilla's Avatar
Default Re: High Idle (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">Nothing came out when you loosened it? </TD></TR></TABLE>
nothing at all
Old Sep 7, 2004 | 07:29 AM
SuperSlow's Avatar
is there anything in the reservoir? Open the radi cap and check you level. It may be a good idea just to go ahead and change/flush. Could be a cheap fix.
Eighty-Nyne
May 10, 2008 11:57 AM
averyvm
17
Jan 17, 2007 11:51 AM
93JDMB18C
Nov 2, 2006 02:03 PM
SOLO1racer
Feb 9, 2005 09:06 AM
ILOVEGIRLS
Mar 31, 2004 12:58 PM
