Distributor Problems
Old Sep 3, 2004 | 10:17 PM
HoNdAmAn29's Avatar
Default Distributor Problems
Awhile back I installed a JDM Motor into my '94 Honda Prelude. When it was first dropped in I was experiencing flat spots in my powerband. Sometimes at low rpm it would bog and want to die. Now it won't start at all and there is no spark to the plugs. There is still power to the distributor. I was wondering if anyone had similar problems. I'm assuming that the distributor is fried and even if it isn't I can't seem to find replacement parts for internal coil distributors so I was going to buy a new one. I was wondering if anyone knew where to buy an internal coil TD60U Ignition Distributor?
Old Sep 4, 2004 | 08:49 AM
esca's Avatar
Default Re: Distributor Problems (HoNdAmAn29)
1. i had the same problem.. it cranks but it doesnt seem to spark right?.. check your fuses.. i paid like 400 for distributor and installation.. when all i had to do was change fuse10 in the fusebox.. (clock/radio/ecu)
2. dont buy a new distributor if you dont have to.. but if you do.. try http://www.distributorking.com
KiD Fr0m Da 516
Jul 28, 2023 11:30 PM
DRAGANDB1
Aug 9, 2018 06:19 PM
carlos8
Jul 25, 2009 09:43 AM
RSX2SIcivic
Oct 27, 2008 11:08 PM
ILuvMyJdmDc4
Nov 27, 2007 04:43 AM
