injectors
Old Sep 7, 2004 | 08:45 AM
lildrgn2.0's Avatar
New User
Default injectors
ok, I believe I have peak and hold injectors (96 Lude). I want to upgrade to some 750's but want to know if I can not use the resistor box and go with saturated injectors, or should I spend twice the money and get the peak and hold injectors?
750 cc saturated from RC = $98 a peice.
750 cc Peak and Hold = $180 a peice..
so can i use saturated and what would be the process to use them?
Old Sep 13, 2004 | 12:41 AM
GOLDBERG's Avatar
Default Re: injectors (Lildrgn)
just a heads up....guy in sponswer place sellin brand new rc 750cc saturateds for like 339 shipped or something..if your gonna go with bigger or peak and hold hit up camp1320.com.... wont be rc but who cares..alot cheaper
Old Sep 13, 2004 | 08:46 AM
PirateMcFred's Avatar
96 lude = OBD2 = Saturated injectors = no resistor box. So, buy some saturated injectors, install and don't worry about it. Nothing to it.
Pirate.
EDIT: I am full of hsit don't listen to me. heheh
Modified by PirateMcFred at 7:32 PM 9/13/2004
Old Sep 13, 2004 | 10:18 AM
lildrgn2.0's Avatar
New User
Default Re: injectors (PirateMcFred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">96 lude = OBD2 = Saturated injectors = no resistor box. So, buy some saturated injectors, install and don't worry about it. Nothing to it.
Pirate.</TD></TR></TABLE>
ERRR.. WRong
96 Lude = OBDII and does have a resistor box.
Old Sep 13, 2004 | 10:21 AM
eLUDEnu
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lildrgn &raquo;</TD></TR><TR><TD CLASS="quote">
ERRR.. WRong
96 Lude = OBDII and does have a resistor box. </TD></TR></TABLE>
Correct!!!!
Old Sep 13, 2004 | 01:48 PM
Speedra500's Avatar
Default Re: injectors (eLUDEnu)
are your current injectors not working?
Old Sep 13, 2004 | 04:14 PM
Behan's Avatar
Default Re: injectors (Speedra500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 &raquo;</TD></TR><TR><TD CLASS="quote">are your current injectors not working?</TD></TR></TABLE>
I'm sure they are working fine, but 240cc injectors on a built turbo set-up is probably not a good idea
Mike, I believe all you have to do is remove the resistor box and wire the injectors without it. I'm not 100% sure though. I know there is info on it in the archives.
Old Sep 13, 2004 | 05:25 PM
Speedra500's Avatar
Default Re: injectors (Behan)
he had 550s i believe, thats why i was asking
Old Sep 13, 2004 | 05:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lildrgn &raquo;</TD></TR><TR><TD CLASS="quote">ERRR.. WRong
Oops, sorry news to me... I guess I was thinking of the 97-01 ludes. But AndyD is right. You can just rewire the harness without the resistor box and use saturated injectors. Look at it this way: no resistor box is less weight to have. *attempt at saving face*
*edit* I looked in my OBD1 helms manual and you just take the 4 red/black wires from the injectors and connect them to the Yellow/black ground going into the Resistor pack. So basically disconnect the resistor pack and cut off the connector and strip the wires and solder them back together and plug the modified plug back into the harness. And then you can run saturated injectors.
Pirate
Modified by PirateMcFred at 7:58 PM 9/13/2004
Old Sep 14, 2004 | 05:00 AM
Behan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 &raquo;</TD></TR><TR><TD CLASS="quote">he had 550s i believe, thats why i was asking</TD></TR></TABLE>
Old Sep 14, 2004 | 06:03 AM
lildrgn2.0's Avatar
New User
THey are 450's... not 550's...
Even if they were 550's... that wouldnt get me more than what 350 to the wheels?
I want more... MORE MORE MORE MORE MORE..
CivicSi95
Feb 16, 2009 01:59 PM
sevenj
May 21, 2008 04:50 PM
boost_is_best
Feb 28, 2006 03:45 PM
hondaaccord94
Jan 16, 2006 06:55 PM
DelsolVtec18
Oct 5, 2001 03:56 PM
