failed emissions need help
Old Sep 2, 2004 | 11:41 AM
noble4ws's Avatar
Default failed emissions need help
ok guys i posted before because i had failed emissions testing, ohio sucks. some said it was because of the 370cc injectors i was running so i got the stock 345's and went again and the numbers are almost identicle here they are
SUPPOSED TO BE
HC----349 / 127 FAIL
CO----5.69 / .71 FAIL
NO----368.5 / 910 PASS
Mysetup is a 92 si 4ws with a 95 h22a(jdm) now with the stock sized 345cc injectors i have an aem intake, cheapo exhaust, high-flow cat, aem pullies, and a ecu that came with the swap (supposed to be a skunk 2 program i know they dont make one for the h22).I am thinking that my ecu is making it run rich, but i dont have money for a stock p13 nor do i want to spend it for it, you guys think it would be ok if i swapped out my h23 p14 in the parking lot and just left it in for them to do the test and then swapped back, i dont want to take a chance of running it too lean, or are there any other options for me. thanks
Modified by noble4ws at 4:25 PM 9/2/2004
Modified by noble4ws at 2:29 AM 9/3/2004
Old Sep 2, 2004 | 11:59 AM
eLUDEnu
Guest
Posts: n/a
Default Re: failed emissions need help (noble4ws)
damn that sucks. im glad I dont have that emissions b.s
Old Sep 2, 2004 | 12:41 PM
thelarkascend1ng's Avatar
whoa i recently got my prelude from akron.
since i don't know too much on the technical side of this kind of thing, often times the best thing you can do is try to get some sympathy from a different mechanic, get to know him for like 2 minutes and drop the car off. there's a place in springfield, VA out here that passed like 5 of my friends cars when they were in reality way too low to pass. if you can't beat em, join em (or something). seriously, just try other mechanics, sometimes they like you and pass you. good luck.
Old Sep 2, 2004 | 10:30 PM
noble4ws's Avatar
thats funny cause i picked up mine from virginia
anyways i think its the ecu just running it rich, what would happen if i swapped the ecu for my h23 ecu right before the test and had them run it with the h23 ecu and just switched back right after the test.
Old Sep 3, 2004 | 12:30 AM
revlimitx04's Avatar
Default Re: (noble4ws)
could be your hi-flo cat... i know alot of em cause failures.. Id check into that.
Old Sep 3, 2004 | 05:37 AM
v4lu3s's Avatar
RTFM
actually there is a supposed skunk2 chip for USDM ecus, and it is richer than the stock usdm program as well.
and as far as i know the h23 ecu is designed to run smaller injectors, so with the fuel mapping being based on teh smaller injectors it could conceivably make your car run even more rich.
Old Sep 3, 2004 | 07:44 AM
noble4ws's Avatar
so is there any way for me to lean out my system without hurting or spending a bunch of money, what if i put the h23 injectors in it?
Old Sep 4, 2004 | 12:35 AM
noble4ws's Avatar
hell i will pay somebody if they are willing to let me swap ecu's if they are in the northeast ohio area, or is there a way for me to "unchip" this ecu, thanks
Old Sep 4, 2004 | 10:12 AM
noble4ws's Avatar
bump i really need some help here guys
Old Sep 5, 2004 | 05:19 PM
v4lu3s's Avatar
RTFM
to "unchip" it you need to put a stock chip back in.
good luck finding someone willing to swp ecus for emissions...
Old Sep 5, 2004 | 10:17 PM
noble4ws's Avatar
yeah no **** and the only other prelude i know of by me is an S model
Punkaddic
Apr 25, 2007 05:32 PM
noble4ws
Jun 20, 2004 09:00 AM
BLACKLUDE97
Dec 8, 2003 08:18 AM
JUNDC2
33
Aug 18, 2003 02:17 PM
Ef Whore
Nov 24, 2002 01:23 PM
