Fool the SRS?
Old Sep 19, 2004 | 10:41 AM
eLuder93's Avatar
Default Fool the SRS?
I have searched all over to try to find the answer to this. Has anyone installed an aftermarket steering hub kit for a new steering wheel, and got the resistor with it to fool the airbag control circuit? Can anyone please put a ohmmeter on it and tell me what the resistance is? I didn't get the right kit from my friend, it has nothing to do with the airbag. I think its somewhere around 2 or 2.2, but it would be great if someone knew for sure. I'm tired of looking at the SRS light.
Old Sep 19, 2004 | 01:37 PM
99_SH's Avatar
Default Re: Fool the SRS? (eLuder93)
Its a 2 ohm 1/4 watt resistor. A 3 ohm should work as well.
The SRS light might come on even after the install, because the computer might dectect that the airbag was unplugged. You will need to reset the SRS unit, by following the instructions in the helms.
Old Sep 19, 2004 | 02:58 PM
eLuder93's Avatar
Default Re: Fool the SRS? (99_SH)
Is that for both 4th and 5th gens?
Old Sep 19, 2004 | 03:20 PM
rjr162's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_SH &raquo;</TD></TR><TR><TD CLASS="quote">Its a 2 ohm 1/4 watt resistor. A 3 ohm should work as well.
The SRS light might come on even after the install, because the computer might dectect that the airbag was unplugged. You will need to reset the SRS unit, by following the instructions in the helms.</TD></TR></TABLE>
as long as you DO NOT turn the ignition on with the airbag unplugged, the unit will never detect that it was unplugged. If you forget, and turn the ignition on with the SRS plug unhooked, then yes, the light will trip and will not go out until you do the reset.
Old Sep 19, 2004 | 04:04 PM
99_SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLuder93 &raquo;</TD></TR><TR><TD CLASS="quote">Is that for both 4th and 5th gens? </TD></TR></TABLE>
yes, along with many other cars... Its pretty standard.
Old Sep 19, 2004 | 04:48 PM
eLuder93's Avatar
thanks... no more light mocking me.
Old Sep 30, 2004 | 06:30 AM
Xgen's Avatar
Can anyone explain where exactly the resistor goes? please i'm desperate here.
Old Sep 30, 2004 | 06:41 AM
Daemione's Avatar
Default Re: Fool the SRS? (honda_guy_83)
It goes right where the airbag normally would plug in. Tricks the computer into thinking it's still there by providing a comparable resistance as the airbag.
Old Sep 30, 2004 | 03:51 PM
Xgen's Avatar
Default Re: Fool the SRS? (Daemione)
But there are 6 terminals at the connector that went to the airbag, which terminals does it go in to?
Old Oct 1, 2004 | 09:12 AM
99_SH's Avatar
The airbag connector in the steering wheel. Not the SRS module
Old Oct 1, 2004 | 09:57 AM
eLuder93's Avatar
ne 1 want to be cool and post the helms' reset procedure for the srs?
Old Oct 1, 2004 | 10:48 AM
Daemione's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLuder93 &raquo;</TD></TR><TR><TD CLASS="quote">ne 1 want to be cool and post the helms' reset procedure for the srs? </TD></TR></TABLE>
You could be even cooler and search for it . . . it's been posted up quite a few times before . . .
i hate import cars
Jun 12, 2008 01:12 PM
lamboextreme
10
Sep 24, 2007 06:09 PM
Rene M
Oct 11, 2006 02:43 PM
92ehatch
Jul 30, 2006 05:57 PM
timmy0tool
Apr 27, 2005 08:13 PM
