All kinds of clunking a in 2001 Base
Old Sep 18, 2004 | 07:40 AM
Doctor Who's Avatar
Default All kinds of clunking in a 2001 Base
So, I have a 2001 base Prelude with 67K on it. When shifting from first to second, I can often hear a slight "clunk" noise coming from the engine bay. I understand that this could be a motor mount, but if so, which one is more likely to be bad? This only happens in low-speed conditions, but nonetheless, it is aggravating all the same.
Also, whenever I make a sharp left-hand turn, I can hear some kind of clunking in what sounds like the trunk. Obviously I've made the check for tennis *****, body parts, etc., so thusly, it's something to do with the car. It sounds almost like the seatbelt buckle smacking the interior panel, but I've already dismissed this as being the cause.
Anyone?
Old Sep 18, 2004 | 08:36 AM
4thGenReady2Go's Avatar
Default Re: All kinds of clunking in a 2001 Base (Doctor Who)
probably the front more than the rear, it could be your exhaust manifold banging against the radiator (which is possible if the engine isn't mated to the front mount).
For the trunk one, did you check to see if your spare tire, tools, and jack are secured?
Old Sep 18, 2004 | 10:35 AM
Doctor Who's Avatar
Default Re: All kinds of clunking in a 2001 Base (4thGenReady2Go)
Thanks for the tip on the mount, but as for the rear, I've already thought about and dismissed the spare tire and accoutrements as culprits.
I remember seeing something about a TSB on this problem, but I forget where I saw it.
Old Sep 18, 2004 | 10:49 AM
i can check to see if there was a TSB for it.
Old Sep 18, 2004 | 11:34 AM
2gn9gencevg's Avatar
Every once while I gets this sound like my seat belt buckle smacked the side of my car. I could never figure out what it was so I just don't worry about it.
Old Sep 18, 2004 | 02:09 PM
phil2000's Avatar
Default Re: All kinds of clunking in a 2001 Base (2gn9gencevg)
I've had both problems in my '00. The first one was indeed a loose motor mount. Was under warranty and Honda found it, so I'm not sure which one. You should be able to tighten both sides and the front mount relatively easily, so try that and see if you're fixed up.
Trunk problem for me was the dreaded "shock knock." Honda did have a TSB related to that and their fix made my problem go away.
Old Sep 18, 2004 | 02:42 PM
p3t312's Avatar
Default Re: All kinds of clunking in a 2001 Base (phil2000)
i had this problem it was my axles so try t o look at ur axle
Nonio
Jan 25, 2018 02:12 AM
friutoftheLude
Nov 23, 2012 04:12 PM
99siRACER
Sep 20, 2012 07:13 AM
PearlWhiteAccord
Nov 8, 2002 11:19 AM
pelotudo
13
Oct 2, 2002 04:34 PM
