Stiff changing gears
Old Sep 16, 2004 | 01:47 PM
es_squared's Avatar
Default Stiff changing gears
just realized it yesterday, the shifter is super hard to get in and out of gears, clutch pedal feels the same as before tho
Old Sep 16, 2004 | 02:00 PM
00LudeLover's Avatar
Default Re: Stiff changing gears (es_squared)
use search feature.
Old Sep 16, 2004 | 02:04 PM
andeh22's Avatar
might be your clutch buddy. clutch pedal will feel the same
you have to shove it into gear right?
you might start having problems where clutch pedal is all the way down, and your car stalls..
but might be many other things. its been discussed alot. searching would help.
Old Sep 16, 2004 | 02:27 PM
es_squared's Avatar
Default Re: Stiff changing gears (andeh22)
i searched a number of things and came uip with nothign useful.. all i saw was change the trans oil
Old Sep 16, 2004 | 02:30 PM
Hawkze_2.3's Avatar
So did you change and fill it to the right level?? That always fixes mine...
Old Sep 16, 2004 | 02:40 PM
blackdelslo's Avatar
Default Re: Stiff changing gears (Hawkze_2.3)
Could the clutch master cylinder be going out? I have to refill mine a little every month because it is leaking inside the car.
Old Sep 16, 2004 | 04:20 PM
es_squared's Avatar
no i havtn had time yet, i just want to know the other possibilities
Old Sep 21, 2004 | 03:04 PM
es_squared's Avatar
ok just changed the tranny fluid and didnt help.
Old Sep 21, 2004 | 04:58 PM
Paulnsx's Avatar
make sure you have fluid in you reservoir. i had a similar problem on my 3rd gen. my guess is that if changing your tranny fluid did nothing it has to do with you master/slave cylinder it could be the clutch itself too like someone else said.
Old Sep 21, 2004 | 08:10 PM
matix's Avatar
Default Re: Stiff changing gears (Paulnsx)
Try bleeding your clutch.
habanerored06si
Honda Civic (2006 - 2015)
Jun 15, 2013 02:12 AM
ryan_
Transmission & Drivetrain
May 27, 2012 11:46 PM
koulninja
25
Mar 5, 2012 05:42 AM
tytyguy
Dec 3, 2005 02:32 AM
juniordc2
Jul 2, 2002 08:33 AM
