CEL Code 9: New Dist, or just replace rotor and cap?
Old Sep 16, 2004 | 09:44 AM
bad-monkey's Avatar
Default CEL Code 9: New Dist, or just replace rotor and cap?
01 base, ~60,000 miles, pulling a code 9.
searched, found some stuff, but what will determine whether i need a new dist or just a new cap and rotor? Car runs fine, no rough idle, maybe a little less peppy than before.
Old Sep 16, 2004 | 09:52 AM
98TypeSH's Avatar
Default Re: CEL Code 9: New Dist, or just replace rotor and cap? (bad-monkey)
I have the same problem. In a previous thread i had told them how to test to see if its the dizzy housing or an actual wiring problem. lemme find it for you
EDIT: here you are, meter these locations.
https://honda-tech.com/zerothread?id=969598
If all is fine there, you need to meter the connections on the ECU female connector. Loop the 2 first and if you got no reading, try one at a time to a ground source. If you get no reading, got a dead wire somewhere.
And it wouldent be the cap a rotor, its the actual dizzy housing that the CYP is connected to.
Also, pull your cap and check to see if you got red dust or anything like that on the inside, if so ignitor took a dump. Depending on the extent of that, you may need a new dizzy.
Modified by 98TypeSH at 11:03 AM 9/16/2004
Old Sep 16, 2004 | 10:04 AM
bad-monkey's Avatar
awesome, thanks dood, i think i have an idea of what might be wrong here.
Old Sep 16, 2004 | 10:12 AM
98TypeSH's Avatar
Default Re: (bad-monkey)
word
Here is a pic anyway of where to meter on the dizzy conector
Meter them together, then 1 at a time to a ground source.
Old Sep 17, 2004 | 02:16 PM
bad-monkey's Avatar
update:
metered them together, got ~179 ohms
to a ground i got 124 for #2, 58 for #4.
sounds like i need a new distributor.
Old Sep 17, 2004 | 02:34 PM
98TypeSH's Avatar
yes. getting a reading from that to ground = bad, replace the dizzy housing or the whole thing. Also, it has to be between 260-460 ohms to be in spec, housing is shot.
Old Sep 17, 2004 | 04:21 PM
ernestoG's Avatar
Default Re: (98TypeSH)
Not trying to thread jack, but I just changed my cap and rotor and I saw some red-orange looking dust and thought nothing of it.
Would the ignitor make the car not wanna start sometimes?
Old Sep 21, 2004 | 07:58 PM
justanotherlude's Avatar
I am also having a problem with it also... I tested my dizzy and i had a ~450 Together, though when I try test it to the ground, it read nothing. Am I connecting everything correctly to get it tested? My helms manual says that i should have from 350 - 700 ohms. Also, when testing to the ecu. Do I need to get those Test harness?
Old Sep 22, 2004 | 09:28 AM
yohan's Avatar
I went through this .. there is a bearring in the dizzy that will go out on you over time, the dust in the cap is the most noticeable sign you've suffered that.
I also had that happen to meand replace my dizz, was throwing code9.
put in a new dizzy and no #9 since.
Old Sep 22, 2004 | 09:32 AM
98TypeSH's Avatar
Default Re: (yohan)
Yohan, did you meter the connectors??
To the other guy, you are not supposed to get a reading from 1 to a ground source, that means its shorted.
Old Sep 22, 2004 | 12:39 PM
You don't meter it to a ground source? I just bought this dizzy in January brand new from flying_pat aka Distributor King.
Old Sep 23, 2004 | 05:13 AM
yohan's Avatar
there was no testing to be done on the dizzy, when I took off the distributor, the part that goes into the camshaft was actually wiggling, it almost felt like it was going to fall off .. $300 for piece of mind, a fix to the problem was worth it ot me ... especially at 100k miles ... plus all the dust being a good sign the bearring was spun.
cd5tuner
Jul 23, 2012 02:36 PM
djviet2000
Aug 3, 2010 02:03 AM
Coolero
11
Oct 25, 2009 11:17 PM
Hym3n
20
Oct 11, 2008 08:24 PM
ludelvr
Jul 18, 2004 04:49 PM
