5th Gen Header question ?
Old Sep 16, 2004 | 12:31 AM
firthy's Avatar
Default 5th Gen Header question ?
I already have the Type S header and 11:1 pistons as they came as standard in the UK on the H22A8 later versions of the Prelude. I have a custom decatted exhaust, CAI and adjustable fuel pressure regulator and will be installing Crower Stage 2 cams, adjustable cam gears, springs, retainers, Apexi VAFC and AEM underdrive pullies.
Would I get any noticeable gains from a different header after installing all of the above as the Type S header is supposed to be pretty good already. Major problem is that Prospeed and SMSP are not available in the UK and the Mugen header is $1500 over here so it is also a cost related issue.
Cheers,
Firthy
Old Sep 16, 2004 | 04:55 AM
StuntMonkeh's Avatar
Default Re: 5th Gen Header question ? (firthy)
Could always import them yourself..... The shipping i was quoted for a mugen header, hi-flow cat and mugen cat back to the UK was quite reasonable. I dunno how all the import tax works out but the supplier I asked was going to label them as second hand.
As for all the technical stuff. I dunno.
Old Sep 16, 2004 | 06:06 AM
breathinez's Avatar
Default Re: 5th Gen Header question ? (StuntMonkeh)
I think a Greddy header would work better. I know they don't make a 5th gen, but you can get the 4th gen hdr and make it longer to fit. If you cut it at the collector and get someone(muffler shop) to weld a stainless 2.5 inch collector with a flex pipe to add to your custom exhaust set up. I think that should work better. But my 2 cents.
Old Sep 23, 2004 | 01:17 AM
Adam R.'s Avatar
Header for H22A8 are the same with TYPE-S OR SH, SiR???
Fei8Lo
Oct 10, 2007 12:57 PM
cxSHOE
Aug 31, 2006 03:53 PM
gina
Sep 6, 2005 01:26 AM
builtprelude
Mar 12, 2004 08:27 AM
SsTiNgEr77
May 2, 2003 12:23 AM
