H23 normal operating temperature
Old Sep 15, 2004 | 02:11 PM
poop32145432's Avatar
Default H23 normal operating temperature
I already did a archived searched for this: what is the normal operating temperature for an H23 engine. My friends Prelude oil and coolant temp seems to run 210 degrees F. I would think it is normal but steam comes from under his hood. Any help will be appreciated.
Old Sep 15, 2004 | 03:05 PM
Skidtron89's Avatar
Default Re: H23 normal operating temperature (mp7235)
You've got a leak in the cooling system somewhere or there could be no syeam unless its from teh radiator cap and then that means your overheating for some reason and it's venting. Sooner or later you will blow a hose apart and over heat. The normal thermostat is like 195 degrees and the cooler one (which I run) is 180 degrees. Try that but 210 is not out of the question at all if the 195 degree thermostat is in there which it probably is. Is the in car temp gauge ever above half way? If not your fine.
wound tight
Jul 23, 2008 07:55 PM
Grenade2k7
Aug 2, 2007 01:59 PM
lude of pre 2.3
Aug 6, 2005 12:18 PM
satan_srv
Nov 21, 2002 06:38 AM
