fuel pump ?
Old Jul 31, 2005 | 03:50 PM
bigbacon2's Avatar
Default fuel pump ?
ok my car cranks and doesnt turn over.its getting spark but no fuel, so i took the incoming line to the fuel filter off and tried to start it no fuel what so ever...so i thought it was the fuel pump relay or the fuel pump.then i learned there is no fuel pump relay just a main relay. can someone tell me what the hell iy might be. it is a 92 lude with an h22 swap
Old Jul 31, 2005 | 05:23 PM
bigbacon2's Avatar
Default Re: fuel pump ? (bigbacon2)
bump
Old Jul 31, 2005 | 05:25 PM
Shakes's Avatar
space cadet
main relay is also known in preludes as the PGM FI Relay. which in other words is your fuel pump relay.
check that and if need by reflow or replace it.
Old Jul 31, 2005 | 05:34 PM
syntax.'s Avatar
in case you meant to ask "where the hell is it", its above the pedals. its a small rectangular grey box. if you swap that out for a known good one and you still have no fuel pressure at all, suspect the fuel pump.
civic28
Mar 26, 2014 04:18 PM
2ndthtsurplace
Apr 10, 2011 11:15 AM
Cameron60
Jan 16, 2007 06:04 PM
whitehf
Aug 6, 2006 01:22 PM
