92 h23 ecu code
Old Aug 1, 2005 | 05:45 PM
bayoufrogg's Avatar
Default 92 h23 check engine problems
trying to find out what code my check engine light is throwing. I jumped the service connector as i was told and turn ign forward and lights just come on as they usually do(no blinking on ch.engine light or any other light - just stayed solid). Do the 4th gen preludes not throw codes like the integras? Not sure here......need a little help.
Modified by bayoufrogg at 8:04 PM 8/1/2005
Old Aug 2, 2005 | 06:24 AM
The Weather Man's Avatar
YOu have to Jump the ecu with the connector.......kinda behind the radio....it should be blue....two pin connector...just stick a paper clip in it....and the engine light should blink a code....long = 10 short = 1......read it....and report back....
Old Aug 2, 2005 | 02:28 PM
bayoufrogg's Avatar
man.....that was what i posted.......i DID that - and got nothing. I know it was the right connector b/c its the same on i used to set my timing. Its just not blinking when i turn the key on. Is there ANY reason it wouldnt blink like it should?
HondachrisEJ1
Feb 16, 2009 06:51 PM
99lsvtecauto
Oct 12, 2003 10:52 AM
projecthybrid04
12
Mar 9, 2003 02:56 PM
NoLipRacen
Jan 29, 2003 11:27 PM
