quick h22 timming question....
Old Aug 5, 2005 | 09:42 AM
turboH22Aakkord's Avatar
Default quick h22 timming question....
ok, i just replaced my dizzy... and i need to adjust the timming... i have a obd1 jdm h22a in a 92 accord.... i was told that i have to adjust the timing through the little hole on the block or on the crank pulley... (i hope not the crank pulley because i have an aftermarket type light weight pulley on it... ) and i have afidanza flywheel as well... thanks guys...
Old Aug 5, 2005 | 09:48 AM
optikal_blitz's Avatar
you need a timing gun.
afaik, you'll need to pull the plug on the timing light hole and adjust the distributor until the timing marks line up correctly as you fire the timing gun into the window.
hth.
Old Aug 5, 2005 | 09:50 AM
jmcmil6's Avatar
Default Re: quick h22 timming question.... (turboH22Aakkord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboH22Aakkord &raquo;</TD></TR><TR><TD CLASS="quote">ok, i just replaced my dizzy... and i need to adjust the timming... i have a obd1 jdm h22a in a 92 accord.... i was told that i have to adjust the timing through the little hole on the block or on the crank pulley... (i hope not the crank pulley because i have an aftermarket type light weight pulley on it... ) and i have afidanza flywheel as well... thanks guys...</TD></TR></TABLE>
if u replaced the dizzy u can adjust it w/ the dizzy... it usually makes it easier if u mark the positioning of the dizzy before u take the orig one off..
that hole in the block is to check timing, not to adjust it specifically
Old Aug 5, 2005 | 10:07 AM
Default Re: (optikal_blitz)
holy man... thanks for the reply... i know i need a timing light, and i have one... but i got a little confused on what i have to do.... im a little slow... take the plug out of the light and huh?? thanks man.
Old Aug 5, 2005 | 10:12 AM
Default Re: quick h22 timming question.... (jmcmil6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmcmil6 &raquo;</TD></TR><TR><TD CLASS="quote">
that hole in the block is to check timing, not to adjust it specifically</TD></TR></TABLE>
yeah.. that is kinda what i ment.. i just need to check the timing.. and i know to adjust the timing i have to turn the dizzy... but how do i check it??
Old Aug 5, 2005 | 10:21 AM
i haven't personally used a timing light but after googling around a bit, i found you need to connect one end of the light to the battery positive (+) another to a chassis ground (-) and attach the clamp to the spark wire. might want to do some more research and confirm it though.
what i was saying before about looking at your timing:
you see that rubber plug where your bell housing of the transmission meets the block? pull that out and youll be able to see your flywheel spinning. you aim the timing light in there and the timing marks will either line up or be off by a positive or negative degree (this dictates how to adjust your dizz)
hope that clears some stuff up.
Old Aug 5, 2005 | 04:17 PM
LudeyKrus's Avatar
-Buy a timing gun.
-Crank your car and warm it up.
-Pull the plug between the tranny and the motor on the front.
-Attach red clamp from timing gun to + battery post, the black clamp from timing gun to the - battery post, and the clamp goes around the #1 spark plug wire....the wire coming from the spark plug nearest the driver's side of the engine.
-Shine the light down into the hole and hit the trigger. Look at the little fork thing and where the 15 mark is.
-Rotate the dizzy till the 15 mark gets between the fork thing.
-You're done!
Old Aug 5, 2005 | 05:16 PM
T-King's Avatar
Default Re: (LudeyKrus)
Keep this in mind, these engines have automatic electronic advance on then, so to say if you go out side and bring your timming from 15 to 16 the ecu will automatically bring it back to 15. To stop it from going that you must go in side the car underneath the center dash piece in the back there is this little plug thing that has a blue head on it with blue and brown wires going into it. You have to stick a jumper in there (or just a bent papper clip) with prevents it from automatically setting it self back, but if it was allready running fine before you changed the dis. you most likely wont have to do that.
Old Aug 6, 2005 | 07:51 AM
Default Re: (T-King)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-King &raquo;</TD></TR><TR><TD CLASS="quote">Keep this in mind, these engines have automatic electronic advance on then, so to say if you go out side and bring your timming from 15 to 16 the ecu will automatically bring it back to 15. To stop it from going that you must go in side the car underneath the center dash piece in the back there is this little plug thing that has a blue head on it with blue and brown wires going into it. You have to stick a jumper in there (or just a bent papper clip) with prevents it from automatically setting it self back, but if it was allready running fine before you changed the dis. you most likely wont have to do that.</TD></TR></TABLE>
is that the same wire that i use to check codes??/
will the timing marks be the same even if i have that fidanza flywheel?
thanks guys for all the help!!
Old Aug 6, 2005 | 09:59 AM
T-King's Avatar
Default Re: (turboH22Aakkord)
yea, it is the same one used to flash codes and I guess the aftermarket flywheel would be the same if it has the same amount of teeth on it.
Old Aug 8, 2005 | 06:14 AM
im pritty familiar with how to run a timing gun... so basicly if i have to adjust the timing though i need to jump the flash code conector and rotate the dizzy... excelent... thanks guys...
LoseRPunKx182
Aug 6, 2005 09:36 PM
NobodysHero
May 1, 2004 11:32 AM
dvp95
Aug 21, 2003 07:45 AM
civbeater90
Nov 16, 2002 12:46 PM
Nick248
Sep 9, 2002 09:59 PM
