Brake Pads and Lines
Old Jul 31, 2005 | 11:30 AM
Yzerman19's Avatar
Default Brake Pads and Lines
I have a question/concern... I dont know anything about brakes except how to change the pads.... but Heres my question/concern... When i was changing the front pads on my prelude.. The right side went fine... but on the left (driver) side When i was pushing the piston back in with a c-clamp... and i got it down to the point close to wear it needed to be.. Some fluid squirted out of the bottom of my car... i got in my car and kept pushing the brake pedal seeing if more would come out but none did... I was wondering if maybe they had like an over flow thing and since both my pistons were pushed back that the fluid went out the over flow.. or did i maybe break open a line and i should be concerned.... please post with any information ASAP!! im afraid to drive till i know.... Thank you
John Langabeer
Old Jul 31, 2005 | 01:11 PM
Eddiebx's Avatar
go check your brake fluid reserviour, most likely you pushed up all the fluid into the reserviour and it overfilled and came out.
that reserviour is near the driverside firewall.
Old Jul 31, 2005 | 01:25 PM
Yzerman19's Avatar
Default Re: (Eddiebx)
okay yea thats right where it kind spilled out right near the driver side fire wall... ill be sure to check it
Old Jul 31, 2005 | 04:30 PM
Yzerman19's Avatar
Default Re: (Yzerman19)
bump
da1lydr1ver
Apr 1, 2012 06:21 PM
namewasdallas
Suspension & Brakes
Apr 6, 2010 08:06 PM
St3v3
Jan 2, 2008 04:52 PM
1337 Si
Apr 12, 2003 07:32 PM
Madracer1
13
Jul 23, 2002 12:49 PM
