Bleeding clutch problem
Old Aug 3, 2005 | 04:08 PM
InfamousLude's Avatar
Default Bleeding clutch problem
I was bleeding the clutch system on my own knowing it seemed like a simple task now I think I have air in my clutch system do i simply do the process over again or is there a different way I should do it now.? The clutch pedal has no pressure at all. How should I fix the problem?
Old Aug 3, 2005 | 04:53 PM
l2yanE's Avatar
Default Re: Bleeding clutch problem (InfamousLude)
Takes 2 ppl to do it, if its bad, ive had to remove the slave and hold it up pretty hight with the bleeder pointing straight up and slowly pump and pump and pump and bleeeed and on and on- took like half an hour after it was all outa the car and in the trunk for awhile.
ramboPandA
May 4, 2015 04:15 PM
88crxdxfastwhip
Jun 5, 2007 01:05 PM
el_dave_o
Sep 30, 2005 04:05 AM
excoupe97
Feb 20, 2005 10:49 AM
justbelowme77
Oct 15, 2004 11:00 AM
