Car keeps stalling
Old Aug 1, 2005 | 12:54 PM
rpv173's Avatar
Default Car keeps stalling
Ok, this is what happens. I start the car and it runs fine as long as my foot is on the gas. If i let go it stalls. This happens everytime. My check engine light came on for error 43 so it has something to do with the Fuel System. Has this happened to anybody before? What should i look for? I read that it could be the O2 sensor or maybe fuel filter?? Is this correct. I thought i ask here first.
I don't know if this would help but this problem started after my timing belt broke/valves bent and i rebuilt the head and replaced the belt.
Thanks
Old Aug 1, 2005 | 03:43 PM
rpv173's Avatar
Default Re: Car keeps stalling (rpv173)
Ok, here's the deal. I went to take off the o2 senser and the damn thing poped right out. Somebody replaced it before because it was a BOSCH aftermarket. Plus, whoever put it in, welded it in. Maybe because it was too small. Maybe that explains why my car wouldn't stay running and why i was getting error 43 from the check engine light.
Old Aug 1, 2005 | 04:55 PM
eMpAtHy's Avatar
wow, you would think that buying a o2 sensor that would fit would be easier than welding one on. did u try replacing the o2 sensor?
Old Aug 1, 2005 | 06:22 PM
rpv173's Avatar
Default Re: Car keeps stalling (eMpAtHy)
Yea, im going to buy one tomorrow. I'm going to replace the fuel filter as well. It's like my engine isn't getting enough fuel or something. It runs with my foot on the gas and then it just stalls out....i can also smell smoke coming from the exhaust. I hope im fixing the right part.
Old Aug 1, 2005 | 08:22 PM
shdriver99's Avatar
You're not!!!
Old Aug 1, 2005 | 09:13 PM
preludeguy_92's Avatar
Default Re: Car keeps stalling (shdriver99)
Helpful
Old Aug 1, 2005 | 10:05 PM
shdriver99's Avatar
Default Re: Car keeps stalling (preludeguy_92)
Only because I've replaced every sensor, the fuel filter, fitv, iacv, coil, igniter, dizzy, main relay and I haven't fixed mine. It possibly could be the O2 which I replaced also but I just don't know!
Old Aug 2, 2005 | 03:37 AM
rpv173's Avatar
At first the car wouldn't spark. I replaced the dist., cap, rotor, coil, plugs, and wires and the damn thing still wasn't starting. So i replaced the ECU and now it starts but stalls without my foot on the gas. It run perfectly past 3000RPMS but once it get below 2000 it starts huggin and chuggin and then eventually stalls.
Old Aug 2, 2005 | 05:35 AM
jdmh22luda's Avatar
mine is basically doin the same ****, im pissed about it---i just changed fuel filter..wasnt that
Old Aug 2, 2005 | 05:36 AM
jdmh22luda's Avatar
Default Re: Car keeps stalling (jdmh22luda)
O2 sensor is being checked nextt.......i have always run an egr code but this is a different problem in itself
Old Aug 2, 2005 | 06:01 AM
The Weather Man's Avatar
What's the UPDATE? Did you replace your o2 sensor yet?..did it work?
Old Aug 2, 2005 | 06:08 AM
rpv173's Avatar
Default Re: (NaptownKing)
I'm at work right now. My father is going try a few more things before he changes it.
phatboycrxhf
Honda Fit
Mar 27, 2013 05:47 PM
young geezer
May 25, 2010 07:02 PM
pedrolucas
Dec 30, 2009 06:34 PM
EGCivicCoupe
Apr 5, 2005 07:36 PM
JinDIESEL
Sep 17, 2004 06:33 AM
