fan help
Old Aug 2, 2005 | 12:21 PM
fastlude69's Avatar
Default fan help
i replaced my fans with slim fans and wired them in the same as the stock fans were. now i'm hitting a probelm that when i turn on my a/c that it doesn't stay on so my a/c hardy works cuz the fan doesn't pull across my condesor, any suggestions? i really don't wanna have to hard wire it.
Old Aug 2, 2005 | 08:00 PM
PrettyLude's Avatar
are the fans blowing the right way?
Old Aug 3, 2005 | 12:12 PM
fastlude69's Avatar
Default Re: (PrettyLude)
yes they are blowing the right way, the problem is the engine fan turns on but the a/c won't stay on while the a/c is on
Old Aug 3, 2005 | 05:38 PM
PrettyLude's Avatar
recheck the wiring, did you test the fan itself to make sure its a working unit?
Old Aug 3, 2005 | 05:46 PM
Ludeachris's Avatar
have you tried wiring the fan through the pressure cycling switch?
Old Aug 3, 2005 | 07:36 PM
fastlude69's Avatar
Default Re: (Ludeachris)
the fan works it turnson with the other fan. just doesn't turn on with the a/c. i just cliped the wires from the stock fans and connected them with the stock plugs from the new fans
Old Aug 3, 2005 | 08:36 PM
onefastrx7turbo's Avatar
Default Re: (fastlude69)
ok, so, they both come on when the ecu turns them on for cooling, but, when you turn the AC on, they dont come on with AC? if thats the case, maybe you missed something in the wiring. check the wiring again, and make sure none of the fuses are blown.
neil
Old Aug 4, 2005 | 02:03 AM
fastlude69's Avatar
Default Re: fan help (fastlude69)
thing is i only unhooked two sets of wires which i hooked back up.
heisenbergtapia
Sep 7, 2016 01:58 PM
silversilver
Nov 10, 2015 09:47 AM
devils_civic
May 13, 2008 01:15 PM
altoid
Aug 5, 2003 03:22 PM
TheIntegraGuy
Jun 9, 2003 08:51 PM
