relay location question
Old Aug 3, 2005 | 05:53 PM
Ludeachris's Avatar
Default relay location question
I have a problem that I know other lude owners have experienced. every once in a while after turning off my car I have a hard time starting it. (94 si) Im almost positive its the relay that controls the fuel pump which according to a chiltons wiring diagram is the main ecu relay. Does anyone know where this relay is?
(the one that controls the fuel pump whatever its called)
Old Aug 3, 2005 | 05:59 PM
PrettyLude's Avatar
its the main relay under the dashboard on the driver side
Old Aug 3, 2005 | 06:06 PM
Ludeachris's Avatar
Default Re: (PrettyLude)
arent there a few relays there?? is it bigger than the others? or something destinctive about it so you can tell it apart?
Old Aug 3, 2005 | 06:50 PM
PrettyLude's Avatar
its pretty distinctive, by the fact that its held onto the dash by some 10mm bolts
Old Aug 4, 2005 | 02:55 PM
jimmyxthai's Avatar
so its that red thing
Old Aug 4, 2005 | 08:16 PM
Honda Sport's Avatar
Default Re: (ludex360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludex360 &raquo;</TD></TR><TR><TD CLASS="quote">so its that red thing
not red, it's a grey box, about 1.5"x2". if you look straight up under your steering column, you should see it.
Mackln308
Aug 21, 2015 08:49 AM
Ludespeed13
Dec 26, 2005 12:20 PM
89 exi nut
Oct 4, 2004 01:45 PM
markvqwerty
Aug 27, 2004 08:52 AM
drew2
Apr 29, 2004 05:02 AM
