93 prelude problem?!?!
Old Aug 5, 2005 | 04:16 PM
gsrhatch87's Avatar
Default 93 prelude problem?!?!
im so lost when i cycle the key over in the prelude the fuel pump doesnt turn on ive replaced the main relay( pgm-fi relay) and checked all fuses and grounds w/ a test light and the fuel pump still doesnt turn on should i hard wire it to sumthin and if so what should i hard wire it to?
Old Aug 7, 2005 | 07:14 AM
Duane_in_Japan's Avatar
Default Re: 93 prelude problem?!?! (gsrhatch87)
You are correct, the power comes direct from the main relay that is turned on by the computer when you first cycle the key on for a few seconds, if it tests good then yoe hot wire the fuel pump, use a fused jumper wire to the battery, hit the hot side or you will blow the fuse if you hit the ground side.
If pump dont work you will need to do a voltage drop test, if pump does work you have a bad wire from the main relay or you didnt test the relay properly, you can just jumper the relay from hot wire to the fuel pump wire, I cant put pics on yet so do some research on the web or this forum.
Old Aug 7, 2005 | 08:17 AM
rfwilson's Avatar
Ok, then I've got something like it. 94 Prelude si. Starts fine first thing in am or when engine cool. Let it run awhile, warm up or drive and shut it down. Then it turns over fine, but will not start....seems like no fuel, but what am I missing. Engine heat affecting something?
Old Aug 7, 2005 | 02:04 PM
bgm93srv's Avatar
I have that problem too. Engine warm- no start but my fuel pressure gauge reads good pressure and I have a new main relay. I think my problem is also caused by engine heat and maybe my msd.
Old Aug 7, 2005 | 06:20 PM
kulrevon's Avatar
Default Re: (bgm93srv)
when you turn your ignition switch to on position with out starting it does your check engine light go on for a sec then turn off?
Old Aug 7, 2005 | 06:29 PM
bgm93srv's Avatar
Not that I noticed, I'll have to check the next time it happens. I really don't think it was. But the first time it kind of started the cel came on right away. From the replies I've received from other boards and such it seems that it might be heatsoke in the Msd
civic89si666
20
Dec 21, 2009 10:25 PM
boosteddohczc
10
Jun 11, 2009 09:57 PM
The AW Alchemist
May 11, 2009 06:35 PM
pprowler6
Dec 26, 2005 09:53 AM
rice4life
16
Sep 4, 2002 12:39 PM
