Shifting Problems
Old Aug 15, 2005 | 06:18 PM
RudeLude95's Avatar
Default Shifting Problems
My car is INCREDIBLY hard to shift into several gears. It's even worse when it comes to downshifting into second; it takes everything in my arm to get it into gear. Sometimes, even then, it makes a horrible grinding noise.
Now, I don't know exactly what the problem is. The car has 110k miles. My friend says it's probably not the transmission itself. The clutch isn't in great shape, but it's far from completely gone. It's "slipping in third." It also has a short shifter in it, which I am thinking is the culprit here. Also, the transmission fluid was changed at 90k. My shop put in "motor oil." Is that the problem? I don't remember what it was like before that because I barely drove the car. I drove it from the previous owners' house to the shop directly.
Any ideas? I'm gonna put in the original shifter tomorrow, to see if that alleviates the problem.
Old Aug 16, 2005 | 12:30 AM
DcWest's Avatar
Default Re: Shifting Problems (RudeLude95)
probably a broken clutch, mine had 2 springs busted out and the were grinding on the flywheel bolts. try a new clutch. did wonders for the way my tarnny feels.
Old Aug 16, 2005 | 06:08 AM
RudeLude95's Avatar
I've been on other sites, and according to other people it's either something with my clutch, whether it be the clutch itself, the pressure plate, or some kind of hose.
Or it's the tranny fluid, which isn't tranny fluid. It's just motor oil.
Old Aug 16, 2005 | 08:11 AM
IHateJDM's Avatar
Default Re: (RudeLude95)
check your shift cables before you start throwing money at it. Just disconnect them from the tranny and see if the shifter moves freely or not.
Old Aug 16, 2005 | 11:57 AM
RudeLude95's Avatar
It's pretty much only downshifting into second gear that's the problem. I just drove it, and it's extremely irritating to deal with it. I have to RAM it into gear sometimes.
It's been doing this for a long time.
Old Aug 16, 2005 | 12:00 PM
BlackLudeSi's Avatar
I'm not sure about the motor oil in you tranny, as far as i know its 80w-90 gear oil that should be in there, some one back me up, my owners manual is way behind my shop. That might be the problem
Old Aug 16, 2005 | 12:01 PM
RemerLex11's Avatar
try not to ram it, thatll wear down your synchros but considering your problem they might be on their last leg anyway.
Old Aug 16, 2005 | 12:12 PM
BB6racer's Avatar
only honda MTF (manual transmission fluid) should be put in your tranny. motor oil will owrk, but MTF will shift MUCH smoother. trust me. and you may want to also replace your clutch, and inspect the flywheel while it's off. i dunno if this sounds like a DIY project to you, but you and a couple buddies should be able to do this in one a weekend.
Old Aug 16, 2005 | 12:38 PM
Eddiebx's Avatar
u can use 5w30 in the tranny no problem
Old Aug 16, 2005 | 12:49 PM
Knightsport's Avatar
El Chico
25 Year Member
Community Builder
Community Influencer
Default Re: (Matt5745767)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt5745767 &raquo;</TD></TR><TR><TD CLASS="quote">try not to ram it, thatll wear down your synchros but considering your problem they might be on their last leg anyway.</TD></TR></TABLE>
First thing I thought of when i read this, synchros.
Old Aug 16, 2005 | 04:11 PM
RudeLude95's Avatar
A lot of people are saying synchros. But the mileage is only 110k, which seems to be awfully low for a manual transmission to last.
I'm gonna put in the Honda MTF I bought today. If that doesn't work, I'll replace the clutch, which is starting to slip anyways.
Old Aug 16, 2005 | 09:30 PM
RemerLex11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RudeLude95 &raquo;</TD></TR><TR><TD CLASS="quote">A lot of people are saying synchros. But the mileage is only 110k, which seems to be awfully low for a manual transmission to last.</TD></TR></TABLE>
EVERYTHING depends on the driver
Old Aug 16, 2005 | 09:31 PM
fwdtamiya's Avatar
Syncros don't have anything to do with it untill you let off the clutch do they? I would check out your clutch.
Old Aug 17, 2005 | 02:57 AM
spiderseth's Avatar
about 15k miles ago my 5th gen 5th and rev. locked up wldn't go into gear at all. I've had no tranny work done on car. Seems honda put the wrong fluid in trans. so after warranty covered everything i got a a new tranny.
Old Aug 17, 2005 | 07:18 AM
RudeLude95's Avatar
Even though I've modded the **** out of the car, I baby it like it crazy. I almost never floor it or anything like that. I NEVER powershift, or bounce off the rev limiter.
Now, maybe the car was abused before I bought it, but I dunno. The car was totalled last Tuesday, but it's almost all cosmetic so I'm either gonna part it out into a new Prelude, or fix the cosmetic body damage and have a new looking car. Either way, I'm gonna see about getting a new clutch and see if that solves the problem.
Pinja
May 6, 2007 09:01 AM
hott-nix
Nov 16, 2004 10:50 PM
thidthad
Apr 29, 2004 10:21 AM
