Problem with passenger power window
Old Aug 10, 2005 | 08:28 AM
Anthrolude's Avatar
Default Problem with passenger power window
Alright.. so the other day my power window on the passenger side decides to go out. did a couple diagnostic stuff and put in a new fuse. It worked. However, the fuse blows everytime the car is turned on again. so, basically i have to put in a new fuse everytime I drive it if i want my window to work. Anyone have a problem like this or any ideas? thanks in advance
Old Aug 10, 2005 | 09:03 AM
Anthrolude's Avatar
Default Re: Problem with passenger power window (tourhcky)
bump
Old Aug 10, 2005 | 09:17 PM
Anthrolude's Avatar
bump for some help
Old Aug 10, 2005 | 11:57 PM
TraKtioN's Avatar
its obviously a short somewhere from the fuse box to the motor, check for continuity between the power motor wires and any grounding point of the car.
Old Aug 11, 2005 | 08:42 AM
Duane_in_Japan's Avatar
Default Re: (TraKtioN)
The wires break at the door hinge area, you should get into the harness and check it out, I would disconnect the door harness from inside the kick panel area, pull it out of the car pillar and do a good inspection, if you dont want to go that deep yet then unplug the door harness from the inside of the car and just let it hang, if the fuse doesnt blow then the short is in the door or in the door harness where it comes intot he car at the pillar and hinge area.
Joey Mitchell
Apr 13, 2019 11:58 AM
lilvietboy
Sep 12, 2008 10:29 PM
artob
Honda Civic (2001 - 2005)
Feb 20, 2008 05:21 PM
GeorgeY
Jun 21, 2003 07:01 PM
