honing question
Old Aug 10, 2005 | 08:50 AM
boostinh22
Guest
Posts: n/a
Default honing question
is there a difference between the hone stones for frm and non-frm sleeves? from the helms, the only difference i can tell is the grit.
Modified by waterboy683 at 4:49 AM 8/15/2005
Modified by waterboy683 at 5:46 PM 8/18/2005
Old Aug 11, 2005 | 08:59 AM
boostinh22
Guest
Posts: n/a
Default Re: honing question (waterboy683)
bump
Old Aug 11, 2005 | 09:03 PM
preludeguy_92's Avatar
It depends on the bore,after the hone, the piston to wall clearance should be .oo7-.03mm give or take .04mm. You may be able to still use B size pistons after you hone.
Piston Diameters:
A: 86.990-87.003mm
B: 86.980-86.993mm
So just pick the one that gives you the best piston to wall clearance.
Edit: This is for an H23 but it should be the same.
Old Aug 18, 2005 | 04:47 PM
boostinh22
Guest
Posts: n/a
bump
Old Aug 19, 2005 | 04:02 PM
boostinh22
Guest
Posts: n/a
up
Old Aug 19, 2005 | 07:56 PM
The Birdman's Avatar
frm requires a different grit stone, you're right on that point. There aren't all that many shops that bore or hone frm blocks. Why are you getting the block honed anyway. You should def. consider sleeving the block while it is out anyway instead of re-honing your stock block. What are your future plans for the motor?
Old Aug 20, 2005 | 01:45 PM
boostinh22
Guest
Posts: n/a
Default Re: honing question (jd3jdm)
just putting in type s pistons. no need for sleeves. after some reading i might not even hone. the cylinder walls are really smooth.
Old Aug 20, 2005 | 02:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by waterboy683 &raquo;</TD></TR><TR><TD CLASS="quote">just putting in type s pistons. no need for sleeves. after some reading i might not even hone. the cylinder walls are really smooth.</TD></TR></TABLE>
Thats not normally what you want. You want a surface for the rings to rub up against and make smooth. I would reccommend to always re-hone when putting different pistons in. My opinion.
HondaMotive
Jan 9, 2014 10:52 AM
cherryredcivic
Nov 22, 2011 06:13 AM
PrinceAli132
Feb 11, 2007 03:10 PM
MatHadder
Oct 1, 2006 05:59 PM
SnOOpY-NO
Jan 12, 2005 08:09 AM
