High pitch howling noise?
I have a 96 Prelude S with 90,000 miles. 2 times this past week the car made a high pitch howling noise. I usually associate a belt making a high pitch squealing noise, but this was louder, and howling noise was the best word I had to describe it.. It was a consiastant high pitch noise..
The first time it happend, I was going into 2nd gear from 3rd, and it did it for a few seconds. This last time, I was at a Mcdonalds drive thru, and it did it for 10 seconds while I was sitting in neutral, and then a few seconds longer as I drove off..
Does anyone know what that sound may be? I am getting a new timing belt and water pump put on next weekend, and I want my car to last til then.
Thanks,
Del
Thanks,
Del
Re: High pitch howling noise? (dELfONiK)
does it sound like its coming from the passenger side by the ecu or tranny? mine goes sometimes from high to low with a high whistling type noise....i took it to the shop that did my car and they said it was the intake making sounds into the manifold? shiot i havent heard anyone's intake to manifold sound like that...
Re: High pitch howling noise? (JDMH22NLINE4)
sounds more like you might have a bearing going bad, My lude lost the power steering pulley bearing at 130,000 miles. Easiest way to check is put a screwdriver right behind the pulleys and place you ear to it while engine running. Obviously don't get caught in the pulley but u should be able to hear it, also works great for dizzy's that might be going bad too.
JDMH22, I know exactly what your talkin about. I had a post about this earlier but couldn't figure it out either. The sound sounds like it's comin from somewhere in the intake manifold. I swapped out my IM, TB with a euro r IM, and RPM TB but the whisling noise is still there.
It makes the noise mostly when the motor warms up huh??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22NLINE4 »</TD></TR><TR><TD CLASS="quote">does it sound like its coming from the passenger side by the ecu or tranny? mine goes sometimes from high to low with a high whistling type noise....i took it to the shop that did my car and they said it was the intake making sounds into the manifold? shiot i havent heard anyone's intake to manifold sound like that...</TD></TR></TABLE>
It actually sounds like it's coming from the driver side... Like I said, it's happend twice. First time for a few seconds, and the most recent time around 15 seconds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackLudeSi »</TD></TR><TR><TD CLASS="quote">sounds more like you might have a bearing going bad, My lude lost the power steering pulley bearing at 130,000 miles. Easiest way to check is put a screwdriver right behind the pulleys and place you ear to it while engine running. Obviously don't get caught in the pulley but u should be able to hear it, also works great for dizzy's that might be going bad too.</TD></TR></TABLE>
Thanks for the reply. I'll have to try that.
milanoredgsr
02-29-2008 06:41 AM
