Engine Damper
Old Aug 10, 2005 | 11:30 AM
97Preludeguy's Avatar
Default Engine Damper
I've searched briefly and I couldn't come up with any Prelude specific engine torque dampers. Can we use the ones offered for Accords? Also, if you have one, how well does it work? Any replies would be great. Thanks in advance
~Chris~
Old Aug 10, 2005 | 07:03 PM
MackDad's Avatar
Default Re: Engine Damper (97Preludeguy)
It works great if you can keep the bracket that attaches to the upper control arm mount on top of the strut mount inside the engine bay from moving.. I think i'm gonna have to have mine welded...(Accord w/ H22A)
And i'm almost positive that it will work on the preludes as they have pretty much the same chassis as the Accord..
Old Aug 11, 2005 | 07:49 AM
Hawkze_2.3's Avatar
Yes, the Accord damper works great, you just have to drill one hole slightly larger to mount it.
Old Aug 11, 2005 | 09:52 AM
Rudelude22's Avatar
where did you happen to get that at?
Old Aug 11, 2005 | 09:54 AM
bb6h22a's Avatar
Default Re: (Rudelude22)
And what about torsional or twist movment of the motor?
That damper looks like money down the tube.
Old Aug 11, 2005 | 10:14 AM
Hawkze_2.3's Avatar
Default Re: (bb6h22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb6h22a &raquo;</TD></TR><TR><TD CLASS="quote">And what about torsional or twist movment of the motor?
That damper looks like money down the tube.</TD></TR></TABLE>
(sarcasm) Oh, wow thanks, I guess I'll have to mount another damper sideways. (sarcasm)
We don't have huge torque-monster electric motors that instantly deliver 500ft/lbs of torque, so I really don't think twisting is anything to worry about. Even if it did twist slightly, would it really even matter??
A damper helps keep engine movement minimal, so it works fine for me.
Old Aug 11, 2005 | 10:32 AM
bb6h22a's Avatar
Default Re: (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
A damper helps keep engine movement minimal, so it works fine for me.</TD></TR></TABLE>
I'm not talking just about the engine's torsional movement, I'm also talking about the damper's movment.
And how do you know you've minimized engine movment, optimally, with the damper?
It's cool, whatever you like, but I'm always skeptical.
Old Aug 11, 2005 | 10:44 AM
Hawkze_2.3's Avatar
It's cool, whatever you like, but I'm always skeptical.</TD></TR></TABLE>
Well, the damper could easily twist in certain places, but it's very rigid along the center axis, which is the only thing needed to keep the eninge still in that one direction. I've never really thought about the engine moving in any other direction that forward/backward.
I know I've minimized the movement based on quicker throttle response and lots more vibration . It's a lot stiffer from idle to acceleration. I don't know that it's optimal though...
Thanks for the mature discussion...I was hoping there wouldn't be any e-arguements.
Old Aug 11, 2005 | 10:59 AM
bb6h22a's Avatar
Well, the damper could easily twist in certain places, but it's very rigid along the center axis, which is the only thing needed to keep the eninge still in that one direction. I've never really thought about the engine moving in any other direction that forward/backward.</TD></TR></TABLE>
If that's what you were going for, it's doing it's job -- it's just that there are usually peripheral concerns that can't be addressed and maybe, if it was measured, 99% of the longitudinal movment could have been eliminated with stiffer motor mounts or inserts -- who knows?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
I know I've minimized the movement based on quicker throttle response and lots more vibration . It's a lot stiffer from idle to acceleration. I don't know that it's optimal though...</TD></TR></TABLE>
It's just hard to rely on the mind -- placebo effect and all.
Thanks for the mature discussion...I was hoping there wouldn't be any e-arguements. </TD></TR></TABLE>
Oh dude you totall suck your car totall suck you are the suck everything sucks
No problem.
Old Aug 11, 2005 | 02:45 PM
MackDad's Avatar
They are $45 at NOPI...
Old Aug 11, 2005 | 03:10 PM
integra15's Avatar
Default Re: (MackDad)
I'll pass on that , but it does look kinda cool.
Old Aug 11, 2005 | 06:08 PM
SHhh__VTEC's Avatar
I've never seen or heard of it before. But it seems like a good item. I can see my motor shake when I start up the motor. I can also see the motor lean back when I revv it too. I give it a thumbs up
civic-one
Sep 7, 2009 05:09 PM
Addickted
Sep 27, 2005 09:18 PM
ghostsi69
May 26, 2005 10:03 PM
jeffhdub2(accord)is
May 16, 2003 01:23 PM
