a/c
Old Aug 10, 2005 | 04:11 PM
phoshizzle88's Avatar
Default a/c
something is wrong with my a/c. it blows cold. but once in a while hot air will come out. then bout a min later it gets cold again.
Old Aug 10, 2005 | 04:33 PM
Pr0jektLude's Avatar
Default Re: a/c (phoshizzle88)
might try recharging it...lol never had this problem i took mine out....but living in the DC area is no fun with no A/C hot weather lots of traffic
Old Aug 10, 2005 | 09:03 PM
GoCarInteg's Avatar
Default Re: a/c (Pr0jektLude)
if it gets cold, then recharging it shouldn't do anything. why don't you get it checked at to see if you have a leak?
Old Aug 10, 2005 | 11:29 PM
Default Re: a/c (GoCarInteg)
well i jus got it recharged couple weeks ago. its not leakin. after i got it recharged it started doin that
Old Aug 11, 2005 | 12:34 AM
GoCarInteg's Avatar
did you recharge it or a shop?
Old Aug 11, 2005 | 12:38 AM
shop
Old Aug 11, 2005 | 05:27 AM
optikal_blitz's Avatar
it sounds electrical..nothing to do with the freeon.
Old Aug 11, 2005 | 05:41 AM
Tomakit's Avatar
Condensor/compressor might be on its way out.
Old Aug 11, 2005 | 05:49 AM
yOnKiNaToR's Avatar
Default Re: a/c (Tomakit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tomakit &raquo;</TD></TR><TR><TD CLASS="quote">Condensor/compressor might be on its way out.</TD></TR></TABLE>
either that, or your climate control box is going bad (common problem on ludes). when the a/c is on look at the a/c button and make sure the green light is on. if it turns off periodically, the soldered contact point for that a/c button is weak and you'll need to tear the climate control apart.
Old Aug 11, 2005 | 07:56 AM
jdmlude_dude's Avatar
Default Re: a/c (yOnKiNaToR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yOnKiNaToR &raquo;</TD></TR><TR><TD CLASS="quote">
either that, or your climate control box is going bad (common problem on ludes). when the a/c is on look at the a/c button and make sure the green light is on. if it turns off periodically, the soldered contact point for that a/c button is weak and you'll need to tear the climate control apart.</TD></TR></TABLE>
exactly what he said....and if that doesnt work..check your expansion valve.
jdm91CrxSi
10
Sep 25, 2007 11:00 AM
ssjtt
12
Apr 11, 2006 10:21 AM
Fangio
Jul 27, 2005 02:41 PM
djseek
13
Jul 9, 2005 09:42 PM
ophdehEEzY
Jul 25, 2003 08:06 PM
