New Setup Questions
Old Nov 6, 2005 | 12:19 PM
DarkBB4's Avatar
Default New Setup Questions
Alright well as Most of you know, (becuase my lame thread has been ttt recently).. My motor has lost compression in 1 cylinder (140)... and i did a wet compression test and it resulted good (no blown rings .. hopefully)...Anyways, I pickied upa new head and i will be doing a head swap (with abuilt one), change headgasket.. and POSSIBLY... cahnging the pistons (my buddy says u can do it when the motor is still in the car. and i have a few questions on the setup.
My motor has 134K on it. If i were to get new pistons (either OEM or TYPE S)... I should get brand new of course but is it worth it to get the type s's.. Where are places i can buy OEM pistons and OEM type s pistons and rods?
My setup (hopefully)
Type S pistons + new rods
JG engine dynamics head
Crower valvesprings + retainers
Upgraded Cams
adj cam gears
JUN flywheel
Exedy clutch
apexi intake
MR header with 2.25 collector
2.25 crush bent
2.36 rsr ex mag exhaust
NGK blues
Chipped P28 ( uberdata)
Hows that set up sound?
sohould i get a Higher compression headgasket? (Cometic?)
other things i should do when i do the headswap (besides timing belt, balance belt, water pump)
Old Nov 6, 2005 | 01:52 PM
LudeyKrus's Avatar
You can, but unless you use OEM pistons and have a good cylinder wall left, I would pull the motor. I wouldn't feel bad about using OEM-style pistons and new rings w/o a hone, if the cylinder walls aren't scratched and they're spec'd out to get the right pistons.
To replace pistons w/ the motor still in the car: drop oil pan/windage tray/girld/mains, remove head. Unbolt rod caps from crank and rotate crank out of the way for each bore. Pull piston/rod out through top. Reinstall is the opposite.
Old Nov 6, 2005 | 01:56 PM
SteveoBA8's Avatar
Default Re: (LudeyKrus)
Balance shaft seal retainer.
Old Nov 6, 2005 | 03:25 PM
BB4vTak's Avatar
Default Re: (TheKingPin)
id imagine you would want the block to be honed at a machine shop.... where it would be fastened down. and done with a press... doing it by hand... i wouldnt try.. if you move slightly.. lean.. tip what ever.. the hone will be uneven and will most likely have sealing problems... not something i would try..
Old Nov 6, 2005 | 03:45 PM
Niles's Avatar
Kingpin, if your cylinders are in good shape (bore roundness and taper) you can use a flex hone to touch up the cross hatching if you are just chaning to new pistons or rings. You shouldn't use a flex hone if your cylinders are out of round, need to be overbored even slightly, or are tapered and need to be re-machined.
For anyone thinking about it... I did the piston/rod swap with the engine still in the car on my first car, it was a major pain, if you're already pulling the pan, head, accessories etc, why not just rent or borrow lift for a couple days you'll have much more space, you'll work faster, and more accuratley, in the end its worth the 30 bucks. just a happy thought good luck!
Old Nov 6, 2005 | 04:10 PM
The Weather Man's Avatar
.....yeah, I'll just go ahead and take the engine out. They're probably out of round anyway. Thanks for the info.
Edit: Ah ****, I'm sorry man. I didn't mean to thread jack. I'll delete my posts.
Old Nov 6, 2005 | 05:40 PM
DarkBB4's Avatar
alright word.. ill just pull the whole engine.. get that **** hottanked
kainoner
18
Mar 31, 2009 09:46 PM
BMO98GSR
May 1, 2008 09:01 PM
BabyBoiGsr
22
Dec 10, 2006 07:52 PM
bounty359
Sep 7, 2005 06:34 AM
TeamMGIperformance
Feb 5, 2004 06:51 PM
