Pulling Check Engine Code, 4th Gen
Old Nov 5, 2005 | 05:48 PM
NSX4evr2006's Avatar
Default Pulling Check Engine Code, 4th Gen
Hey guys,
I searched here and couldn't find anything on how to actually jump the ecu to get the CEL to flash the code. Could anyone explain?
Thanks.
Old Nov 5, 2005 | 06:25 PM
MadCityLude
Guest
Posts: n/a
Default Re: Pulling Check Engine Code, 4th Gen (NSX4evr2006)
Sorry man, I found this before but can't seem to find it now.
Old Nov 5, 2005 | 06:26 PM
BB6racer's Avatar
find the obd port with 2 wires, and then take a paper clip (or some other sort of U shaped metal, and push it in the obd port with 2 wires. turn the ignition key to the on position and look at the check engine light. it will flash in a certain pattern: the slow flashes are for the 2nd digit, and the fast flashes are for the 1st digit (ei. 2 slow flashes and then 6 quick flashes will be 26). or maybe i have the quick and slow flash thing backwards... anyone know if slow flashes are for the 1st or 2nd digit?
Old Nov 5, 2005 | 06:31 PM
Any way you could give me the general area the obd port is in......im assuming near the passenger seat?
Old Nov 5, 2005 | 06:51 PM
Found it.
http://www.92lude.com/diagnose_error_codes.htm
racekar
Sep 20, 2004 11:28 AM
rhemu1
Aug 6, 2004 08:09 AM
Log4n
Mar 15, 2003 05:11 AM
GSRdriver
Dec 25, 2001 12:48 AM
Drew313
Dec 10, 2001 08:04 AM
