Code One and Code 43
Old Nov 6, 2005 | 12:34 PM
NSX4evr2006's Avatar
Default Code One and Code 43
Hey guys--
I just pulled these 2 codes from the CEL.
43 i see is "FUEL SUPPLY SYSTEM" and 1 is "OXYGEN SENSOR"
What do I need to have done to have these fixed?
Old Nov 6, 2005 | 06:27 PM
Jagan'92's Avatar
Default Re: Code One and Code 43 (NSX4evr2006)
Reset your ECU to make sure these codes continue to occur.
Then,
Try replacing the fuel filter, since that's cheap and easy. other things to start with in order of cheapest/easiest would be the O2 sensor, injectors, cat and fuel pump.
Old Nov 6, 2005 | 06:30 PM
DarkBB4's Avatar
Default Re: Code One and Code 43 (Jagan'92)
all u have to do is replace the o2 sensor.. and it will take away code 43 most likely.
if u have a 92-96 prelude.. i have an o2 sensor that will work for u (not thraed jacking)
OEM.... accord.. wired for prelude.. 60 shpped obo
dejay2014
Aug 24, 2014 09:16 PM
JDM_SOHC
Apr 12, 2009 02:38 PM
tonyguns
Apr 21, 2008 03:33 PM
AccordEX1991
Aug 6, 2007 02:49 PM
95civicracer
Nov 21, 2003 10:29 AM
