Engine not starting..
Old Nov 4, 2005 | 08:53 PM
Lenne's Avatar
Default Engine not starting..
I turned my boost all the way down.... the car started then it died.....
but after I tried to start it after that it won't start...
i put the boost back to where it was and it still doesn't start...
i tried leaving it for an hour and still same thing....
so im wondering how im going to start the car up..
i have no idea why it's not starting...
it had an idle problem but it started fine when the engine was cold....
Old Nov 5, 2005 | 02:38 PM
MadCityLude
Guest
Posts: n/a
Default Re: Engine not starting.. (Lenne)
1st check for spark on all cylinders (pull the plug wires and test with a plug. If there is no spark. Try a new plug. if still nothing check rotor condition! then inspect wires.
If you have spark check for fuel. 1st listen for fuel pump. then check for pressure. check injectors.
Could also be your Dizzy
Old Nov 6, 2005 | 09:50 AM
Lenne's Avatar
checked rotor..
ill try the spark plugs...
REDEM1FTW
18
Nov 6, 2010 06:08 AM
em1_fox
Oct 28, 2007 12:11 PM
si_motor_spt
Sep 2, 2007 06:57 PM
chu77
Sep 11, 2006 08:10 PM
mustninty
17
May 24, 2004 12:52 PM
